Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement
  1. Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement, Unplug: step 1, image 1 of 1
    • Before starting, remember to disconnect the outlet from the area.
  2. Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 2, image 1 of 2 Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 2, image 2 of 2
    • Remove the three screws from the pad.
    • Then the three screws of the holding flange.
  3. Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 3, image 1 of 3 Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 3, image 2 of 3 Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 3, image 3 of 3
    • Be careful to keep the three small balls.
  4. Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 4, image 1 of 2 Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 4, image 2 of 2
    • Unscrew the screws to open the shell.
  5. Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 5, image 1 of 2 Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 5, image 2 of 2
    • Remove the pendulum and recover the bearing.
  6. Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 6, image 1 of 1
    • Remember to put back some fat before replacing the new pendulum.
    • Replace the new part.
  7. Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 7, image 1 of 1
    • Before closing, check that no cables are blocked and that each room is in its housing.
    • Replace the screws on the shell.
  8. Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 8, image 1 of 3 Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 8, image 2 of 3 Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 8, image 3 of 3
    • Replace the holding flask, be careful to have the three small balls.
  9. Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 9, image 1 of 2 Dexter 300W Corded Delta Sander - 300DS2.5 Toothed Wheel Replacement: step 9, image 2 of 2
    • Line the three screws of the holding flange and then that of the pad.
To reassemble follow guide or in reverse
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,608 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 9
All Time: 238
