Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable
  1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable, Unplug: step 1, image 1 of 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 2, image 1 of 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 2, image 2 of 2
    • Remove the dust case and the seal on the back of the device.
  3. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 3, image 1 of 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 3, image 2 of 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 3, image 3 of 3
    • Unscrew the six screws from the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 4, image 1 of 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 4, image 2 of 2
    • Using a screwdriver or screwdriver, unscrew and open the device.
  5. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 5, image 1 of 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 5, image 2 of 2
    • Unscrew the two screws from the domino to pull out the brown and blue cables.
  6. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 6, image 1 of 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 6, image 2 of 2
    • Reconnect the new cable to the domino.
    • Then replace the cable, the sheath must arrive between the two pads and the sleeve must be positioned in its housing.
  7. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 7, image 1 of 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 7, image 2 of 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 7, image 3 of 3
    • Replace the shell, then screw it back on.
    • Remember to put the joint back in its place.
  8. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 8, image 1 of 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 8, image 2 of 2
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  9. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 9, image 1 of 1
    • Finally, reposition the vacuum bag.
Finish Line
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,581 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 147
