Dexter 750W Corded Jigsaw Motor Replacement
Céline Chemineau
Céline Chemineau and one other contributor
Last updated on August 7, 2022
5 minutes
Easy
Grammar Police
Community-Contributed Guide
Better Introduction
Introduction
Go to step 1
This guide will show you how to replace your motor
  1. Dexter 750W Corded Jigsaw Motor Replacement, Unplug: step 1, image 1 of 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 750W Corded Jigsaw Motor Replacement: step 2, image 1 of 1
    • Remove the vacuum adapter from the back of the device.
  3. Dexter 750W Corded Jigsaw Motor Replacement: step 3, image 1 of 2 Dexter 750W Corded Jigsaw Motor Replacement: step 3, image 2 of 2
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Unlock the tray by lifting the lever.
    • Use needle nose pliers and remove the clip located next to the blade holder.
    • Remove the blade holder, keeping the slider at the end of the holder.
  4. Dexter 750W Corded Jigsaw Motor Replacement: step 6, image 1 of 1
    • Unscrew the two screws and set them aside.
    • Remove the two carbons located next to the stator.
    • Lift the stator, then lever out the motor.
  5. Dexter 750W Corded Jigsaw Motor Replacement: step 9, image 1 of 1
    • Put the new motor back in its place.
  6. Dexter 750W Corded Jigsaw Motor Replacement: step 10, image 1 of 2 Dexter 750W Corded Jigsaw Motor Replacement: step 10, image 2 of 2
    • Collect the end cap on the old engine.
    • Put it back on the new motor.
    • Put some grease on the tip.
  7. Dexter 750W Corded Jigsaw Motor Replacement: step 11, image 1 of 1
    • Replace the two screws to stabilize the motor.
    • Return the blade holder to its location
    • Make sure you put each piece in its place.
    • Replace the staple in the same location. The curved side of the staple should go to the rounded side of the bracket.
    • Lubricate the whole
  8. Dexter 750W Corded Jigsaw Motor Replacement: step 14, image 1 of 2 Dexter 750W Corded Jigsaw Motor Replacement: step 14, image 2 of 2
    • Put the coals back in their places.
  9. Dexter 750W Corded Jigsaw Motor Replacement: step 15, image 1 of 1
    • Before closing, lubricate each gear.
  10. Dexter 750W Corded Jigsaw Motor Replacement: step 16, image 1 of 1
    • Close and screw the device.
follow guide through or in reverse to reassemble
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,698 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
38 Members
241 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 8
Past 30 Days: 18
All Time: 643
