Dexter 750W Wired Jigsaw Power Cable Replacement
  1. Dexter 750W Wired Jigsaw Power Cable Replacement, Unplug: step 1, image 1 of 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 750W Wired Jigsaw Power Cable Replacement: step 2, image 1 of 1
    • Remove the vacuum adaptor on the back of the device.
  3. Dexter 750W Wired Jigsaw Power Cable Replacement: step 3, image 1 of 2 Dexter 750W Wired Jigsaw Power Cable Replacement: step 3, image 2 of 2
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Unlock the tray by lifting the lever.
  4. Dexter 750W Wired Jigsaw Power Cable Replacement: step 4, image 1 of 1
    • Remove the two screws to unlock the cable.
  5. Dexter 750W Wired Jigsaw Power Cable Replacement: step 5, image 1 of 1
    • Remove the black screw, in order to remove the wheel.
    • Thanks to a screwdriver, leverage to be able to recover the wheel.
  6. Dexter 750W Wired Jigsaw Power Cable Replacement: step 7, image 1 of 2 Dexter 750W Wired Jigsaw Power Cable Replacement: step 7, image 2 of 2
    • Turn the switch over.
    • Unscrew the 2 screws to remove the blue and brown cables.
  7. Dexter 750W Wired Jigsaw Power Cable Replacement: step 8, image 1 of 1
    • Reconnect the new cable.
    • The brown thread must be at the top and the blue thread must be at the bottom.
  8. Dexter 750W Wired Jigsaw Power Cable Replacement: step 9, image 1 of 2 Dexter 750W Wired Jigsaw Power Cable Replacement: step 9, image 2 of 2
    • Reposition each room in its housing.
    • Then screw each screw.
  9. Dexter 750W Wired Jigsaw Power Cable Replacement: step 10, image 1 of 1
    • Close and screw the device.
Finish Line
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,581 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 300
