Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable
  1. Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable, Unplug: step 1, image 1 of 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable: step 2, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable: step 2, image 2 of 2
    • Remove the handle from the machine.
  3. Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable: step 3, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable: step 3, image 2 of 2
    • Using a screwdriver or screwdriver, unscrew and open the device.
  4. Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable: step 4, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable: step 4, image 2 of 2
    • Lift the switch and unscrew the screws to release the cable.
  5. Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable: step 5, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable: step 5, image 2 of 2
    • Replace the new power cable and connect the cables to the switch.
    • Replace the switch in its housing.
  6. Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable: step 6, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable: step 6, image 2 of 2
    • Before closing, check that no cable is blocked and that each part is in its place.
    • Tighten the screws to close the device.
  7. Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable: step 7, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Replacement Power Cable: step 7, image 2 of 2
    • Finally replace the handle.
To reassemble complete steps in reverse or complete guide
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,581 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 218
