Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement
  1. Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement, Unplug: step 1, image 1 of 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 2, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 2, image 2 of 2
    • Remove the handle from the machine.
  3. Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 3, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 3, image 2 of 2
    • Using a screwdriver or screwdriver, unscrew and open the device.
  4. Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 4, image 1 of 1
    • Unscrew the four screws.
    • Using a screwdriver, lift the spring of the two brushes.
    • Lift the rotor and the stator and disassemble them.
  5. Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 7, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 7, image 2 of 2
    • Disassemble the two parts.
  6. Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 8, image 1 of 1
    • Before reassembling the new part, be sure to re-grease.
  7. Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 9, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 9, image 2 of 2
    • Reassemble the two parts and replace them in their place.
    • Reposition the brush springs.
  8. Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 11, image 1 of 1
    • Then retighten the four screws.
  9. Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 12, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 12, image 2 of 2
    • Before closing, check that no cable is blocked and that each part is in its place.
    • Tighten the screws to close the device.
  10. Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 13, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Rotor Replacement: step 13, image 2 of 2
    • Finally replace the handle.
By the end of the guide you will have successfully replaced the rotor
To reassemble perform the steps in reverse
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,581 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
One Comment
Hi,
Nice post and video but where can I purchase a new rotor for my drill?-the 2 links in the post do not work.
Thanks!
Nick Berrow - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 31
All Time: 491
