Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable
  1. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable, Unplug: step 1, image 1 of 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: step 2, image 1 of 2 Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: step 2, image 2 of 2
    • Unscrew the screws of the hull to open it.
  3. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: step 3, image 1 of 2 Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: step 3, image 2 of 2
    • Unscrew the cable clamp.
  4. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: step 4, image 1 of 1
    • Remove the two screws from the switch.
    • Then remove the cable.
  5. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: step 5, image 1 of 3 Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: step 5, image 2 of 3 Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: step 5, image 3 of 3
    • Reconnect the new cable to the switch, then tighten the cable clamp.
  6. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: step 6, image 1 of 2 Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: step 6, image 2 of 2
    • Before closing, check that no cable is blocked and that each part is in its place.
    • Then retighten the hull screws.
By the end of the guide you will have successfully replaced your power cable
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,608 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 147
