Dexter Corded Belt Sander - 900BS2.5 Motor Replacement
  1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement, Unplug: step 1, image 1 of 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 2, image 1 of 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 2, image 2 of 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 2, image 3 of 3
    • Remove the handle, by unscrewing the screw.
  3. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 3, image 1 of 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 3, image 2 of 2
    • Pry the tape off.
  4. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 4, image 1 of 1
    • Unscrew the 4 screws.
  5. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 5, image 1 of 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 5, image 2 of 2
    • Remove the belt, then unscrew the screws of the shell to gain access to the motor.
    • Collect the belt to place it in the new room.
  6. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 6, image 1 of 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 6, image 2 of 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 6, image 3 of 3
    • Remove both accessories.
  7. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 7, image 1 of 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 7, image 2 of 2
    • Remove the screws from the hull in order to have access to the interior and allow the carbon brushes to be blocked.
    • Relax the small metal strip to be able to separate the carbons.
    • Replace the new part in its housing.
  8. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 10, image 1 of 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 10, image 2 of 2
    • Open the cap of the new part to replace the belt.
    • Tighten the inner screw.
  9. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 11, image 1 of 1
    • Tighten the four screws.
  10. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 12, image 1 of 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 12, image 2 of 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: step 12, image 3 of 3
    • Replace the tip, band and handle.
Finish Line
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,608 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 143
