Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System
  1. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System, Unplug: step 1, image 1 of 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 2, image 1 of 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 2, image 2 of 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 2, image 3 of 3
    • Remove the handle, unscrewing the screw
  3. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 3, image 1 of 2 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 3, image 2 of 2
    • Remove the strip by leverling
  4. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 4, image 1 of 1
    • Remove the front cover to have more space.
  5. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 5, image 1 of 1
    • Remove the two screws on the shell.
  6. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 6, image 1 of 1
    • Turn the machine over and unscrew the large screw.
    • Unscrew the orange wheel to be able to lift it.
  7. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 8, image 1 of 1
    • Remove the spring from the old part to put it back on the new one.
  8. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 9, image 1 of 1
    • Put the spring back.
    • Tighten the orange wheel.
  9. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 11, image 1 of 1
    • Put the two screws back on the side and the large screw.
  10. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 12, image 1 of 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 12, image 2 of 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: step 12, image 3 of 3
    • Replace the tip, strip and handle.
Finish Line
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,608 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 331
