Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable
  1. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable, Unplug: step 1, image 1 of 1
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 2, image 1 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 2, image 2 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 2, image 3 of 3
    • Remove the handle, unscrewing the screw.
  3. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 3, image 1 of 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 3, image 2 of 2
    • Pry the tape off.
  4. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 4, image 1 of 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 4, image 2 of 2
    • Unscrew the screws to open the hull.
  5. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 5, image 1 of 1
    • Remove the two screws that block the cable.
  6. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 6, image 1 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 6, image 2 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 6, image 3 of 3
    • Release the brown cable.
    • Unscrew the screw on the domino.
  7. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 7, image 1 of 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 7, image 2 of 2
    • Then release the blue cable.
  8. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 8, image 1 of 1
    • Remove the old cable and replace it with the new one.
  9. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 9, image 1 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 9, image 2 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 9, image 3 of 3
    • Put the cables back in their place and screw the domino and switch. Then put each room back into their home.
    • The brown cable must be positioned below.
  10. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 10, image 1 of 1
    • Close and screw the device.
  11. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 11, image 1 of 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: step 11, image 2 of 2
    • Replace the band and handle.
Finish Line
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,608 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 122
