Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable
  1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable, Unplug: step 1, image 1 of 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 2, image 1 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 2, image 2 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 2, image 3 of 3
    • Remove the handle, by unscrewing the screw.
  3. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 3, image 1 of 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 3, image 2 of 2
    • Remove the strip by leverling.
  4. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 4, image 1 of 1
    • Unscrew the 4 screws.
  5. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 5, image 1 of 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 5, image 2 of 2
    • Remove the belt, then unscrew the screws from the shell to access the engine.
  6. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 6, image 1 of 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 6, image 2 of 2
    • Remove the screws from the hull to have access inside and allow the coals to be blocked.
    • Lift the speed variator, you can use a small screwdriver to get it out.
  7. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 8, image 1 of 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 8, image 2 of 2
    • Turn the dimmer over to have good access to be able to unweld the wires.
    • Unweld the cables connected to the motor and suck the excess with a pump.
  8. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 10, image 1 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 10, image 2 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 10, image 3 of 3
    • Unscrew the two screws from the switch to extract the second cable.
    • To extract the cables you can use a clamp.
    • Change the speed variator and then disconnect the cable from the switch.
    • Reseating the motor cables to the dimmer.
  9. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 13, image 1 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 13, image 2 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 13, image 3 of 3
    • Replace the dimmer in its housing.
    • Be careful to put the cables back on so that it is not pinched.
  10. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 14, image 1 of 1
    • Screw the four screws.
  11. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 15, image 1 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 15, image 2 of 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: step 15, image 3 of 3
    • Replace the tip, strip and handle.
Finish Line
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,608 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 172
