Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement
  1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement, Unplug: step 1, image 1 of 1
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 2, image 1 of 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 2, image 2 of 2
    • Remove the dust box and the seal on the back of the device.
  3. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 3, image 1 of 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 3, image 2 of 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 3, image 3 of 3
    • Unscrew the six screws of the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 4, image 1 of 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 4, image 2 of 2
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Lift the two carbons with a screwdriver to get them out of their homes.
    • Remove the rotor from its housing.
    • Press the tab to disconnect the coal from the engine.
    • Unscrew the domino screws to disconnect the cables.
    • Use a clamp to extract the cables.
  5. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 9, image 1 of 1
    • Separate the wire connected to the motor.
    • Cut the rat cable with a cutting pliers.
  6. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 11, image 1 of 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 11, image 2 of 2
    • Unsolder the cable connected to the speed dimmer.
    • Approach the soldering iron to heat the tin and make it soft. Using the pump, remove the residues.
  7. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 13, image 1 of 1
    • Take out the old engine to replace it with the new one.
  8. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 14, image 1 of 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 14, image 2 of 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 14, image 3 of 3
    • Replace the cable of the new motor on the speed dimmer.
    • You must take the shortest cable.
    • With tin, unsolder the wire on the frame to hold it.
    • Replace the speed dimmer in its housing.
  9. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 17, image 1 of 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 17, image 2 of 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 17, image 3 of 3
    • Replace the most black thread in the domino.
  10. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 18, image 1 of 1
    • Replace each room in its housing.
    • Reconnect the carbons.
  11. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 20, image 1 of 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 20, image 2 of 2
    • Replace the new engine.
    • Remember to recover the small washer at the end of the old piece.
  12. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 21, image 1 of 1
    • Replace the engine at its location.
  13. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 22, image 1 of 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 22, image 2 of 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 22, image 3 of 3
    • Be careful to put the black cable back into its housing so as not to block during the reassembly of the machine.
    • Put the carbons back in their place.
  14. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 24, image 1 of 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 24, image 2 of 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 24, image 3 of 3
    • Replace the shell, then screw it back on.
    • Remember to put the joint back in its place.
  15. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 25, image 1 of 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 25, image 2 of 2
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  16. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: step 26, image 1 of 1
    • Finally, reposition the vacuum bag.
Finish Line
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,608 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 161
