Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable
  1. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable, Unplug: step 1, image 1 of 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: step 2, image 1 of 2 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: step 2, image 2 of 2
    • Remove the side handle and the protective cover.
  3. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: step 3, image 1 of 2 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: step 3, image 2 of 2
    • Unscrew the 4 screws to open the machine.
  4. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: step 4, image 1 of 3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: step 4, image 2 of 3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: step 4, image 3 of 3
    • Remove the switch from his housing in order to have access to it.
    • Unscrew the two screws to disconnect the cables.
  5. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: step 5, image 1 of 3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: step 5, image 2 of 3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: step 5, image 3 of 3
    • Replace the cable and reconnect the cables to the switch.
    • Be careful to put the sheath back between the two studs.
  6. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: step 6, image 1 of 1
    • Before closing, check that no cables are blocked.
    • Screw the 4 screws to close.
  7. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: step 7, image 1 of 2 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: step 7, image 2 of 2
    • Replace the external flange, the protective cover and the side handle.
Finish Line
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,581 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 116
