DigiLand DL700D Battery Replacement
  1. DigiLand DL700D Battery Replacement, Battery: step 1, image 1 of 3 DigiLand DL700D Battery Replacement, Battery: step 1, image 2 of 3 DigiLand DL700D Battery Replacement, Battery: step 1, image 3 of 3
    • Remove the device's back cover using the plastic opening tool.
  2. DigiLand DL700D Battery Replacement: step 2, image 1 of 3 DigiLand DL700D Battery Replacement: step 2, image 2 of 3 DigiLand DL700D Battery Replacement: step 2, image 3 of 3
    • Remove the three pieces of adhesive placed over the edges of the battery.
  3. DigiLand DL700D Battery Replacement: step 3, image 1 of 1
    • Remove the wifi antenna from the bottom of the battery.
  4. DigiLand DL700D Battery Replacement: step 4, image 1 of 3 DigiLand DL700D Battery Replacement: step 4, image 2 of 3 DigiLand DL700D Battery Replacement: step 4, image 3 of 3
    • Heat up the soldering iron, proceed to desolder and remove the battery connections.
  5. DigiLand DL700D Battery Replacement: step 5, image 1 of 3 DigiLand DL700D Battery Replacement: step 5, image 2 of 3 DigiLand DL700D Battery Replacement: step 5, image 3 of 3
    • Remove the battery from the casing using a nylon spudger.
    • Be careful not to puncture the battery casing.
    • Carefully peel the battery free from the casing.
To reassemble your device, follow instructions in the reverse order. Apply new Kapton Tape and apply extra solder as needed.
Justin Edwards
241 Reputation
2 Guides authored
IUPUI, Team S3-G4, Harley Spring 2018 Member of IUPUI, Team S3-G4, Harley Spring 2018
IUPUI-HARLEY-S18S3G4
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 446
