DigiLand DL8006 Motherboard Replacement
  1. DigiLand DL8006 Motherboard Replacement, Motherboard: step 1, image 1 of 2 DigiLand DL8006 Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Remove the backing of the tablet to reveal the internal components using a plastic opening tool.
  2. DigiLand DL8006 Motherboard Replacement: step 2, image 1 of 1
    • Peel back the metallic tape connecting the motherboard to the tablet body with your fingers.
  3. DigiLand DL8006 Motherboard Replacement: step 3, image 1 of 3 DigiLand DL8006 Motherboard Replacement: step 3, image 2 of 3 DigiLand DL8006 Motherboard Replacement: step 3, image 3 of 3
    • Remove the battery plug from the motherboard.
    • Fingers may be used to gently wiggle the connector out if it becomes stuck.
    • If battery wires are under the ribbon, Do Step #4 first.
  4. DigiLand DL8006 Motherboard Replacement: step 4, image 1 of 2 DigiLand DL8006 Motherboard Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Opening the locking tab of the ZIF connector and carefully remove the upper section of the ribbon cable from the motherboard using tweezers.
  5. DigiLand DL8006 Motherboard Replacement: step 5, image 1 of 2 DigiLand DL8006 Motherboard Replacement: step 5, image 2 of 2
    • Disconnect the three remaining ribbons by opening the locking tabs of the ZIF connectors and gently pulling the cables out.
    • Use tweezers to manipulate the connectors and ribbons to prevent damage.
  6. DigiLand DL8006 Motherboard Replacement: step 6, image 1 of 3 DigiLand DL8006 Motherboard Replacement: step 6, image 2 of 3 DigiLand DL8006 Motherboard Replacement: step 6, image 3 of 3
    • Remove the 3 mounting screws from the motherboard with a Phillips #0 screwdriver.
    • One of the screws is located under a ribbon. You will need to gently peel back the cable to access it (see image 3).
  7. DigiLand DL8006 Motherboard Replacement: step 7, image 1 of 1
    • Gently remove the motherboard from the case.
Alec Trela
327 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 200
