DigiLand DL8006 Speaker Replacement
  1. DigiLand DL8006 Speaker Replacement, Speaker: step 1, image 1 of 1
    • Begin by opening the device around its edge using the iFixit opening tool.
  2. DigiLand DL8006 Speaker Replacement: step 2, image 1 of 2 DigiLand DL8006 Speaker Replacement: step 2, image 2 of 2
    • Remove the metallic tape that covers the lower section of the battery.
  3. DigiLand DL8006 Speaker Replacement: step 3, image 1 of 2 DigiLand DL8006 Speaker Replacement: step 3, image 2 of 2
    • Remove the three battery screws using a Phillips #0 screwdriver.
  4. DigiLand DL8006 Speaker Replacement: step 4, image 1 of 3 DigiLand DL8006 Speaker Replacement: step 4, image 2 of 3 DigiLand DL8006 Speaker Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Pop up the locking tab of the ZIF connector using tweezers, and carefully pull the cable out from the motherboard.
    • Make sure the ribbon passes under the microphone wiring to avoid damage to the components.
    • Remove the lower section of the ribbon cable repeating the previous bullet.
  5. DigiLand DL8006 Speaker Replacement: step 5, image 1 of 1
    • Remove the battery from the phone using the iFixit opening tool or the spudger.
  6. DigiLand DL8006 Speaker Replacement: step 6, image 1 of 2 DigiLand DL8006 Speaker Replacement: step 6, image 2 of 2
    • Finally, remove the speaker from the tablet using the spudger.
    • In this image, a screwdriver was used to pry the speaker from its housing. You should use an ESD-safe tool to avoid causing damage to your device.
Alec Trela
327 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 157
