DigiTech RP70 Amp/Mixer Switch Replacement
  1. DigiTech RP70  Amp/Mixer Switch Replacement, Motherboard: step 1, image 1 of 2 DigiTech RP70  Amp/Mixer Switch Replacement, Motherboard: step 1, image 2 of 2
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70  Amp/Mixer Switch Replacement: step 2, image 1 of 2 DigiTech RP70  Amp/Mixer Switch Replacement: step 2, image 2 of 2
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70  Amp/Mixer Switch Replacement: step 3, image 1 of 1
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70  Amp/Mixer Switch Replacement: step 4, image 1 of 1
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. DigiTech RP70  Amp/Mixer Switch Replacement, Amp/Mixer Switch: step 5, image 1 of 1
    • Desolder the back of the motherboard where you want to replace the switch.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 409
