DigiTech RP70 DC Power Connector Replacement
  1. DigiTech RP70 DC Power Connector Replacement, Motherboard: step 1, image 1 of 2 DigiTech RP70 DC Power Connector Replacement, Motherboard: step 1, image 2 of 2
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 DC Power Connector Replacement: step 2, image 1 of 2 DigiTech RP70 DC Power Connector Replacement: step 2, image 2 of 2
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 DC Power Connector Replacement: step 3, image 1 of 1
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 DC Power Connector Replacement: step 4, image 1 of 1
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. DigiTech RP70 DC Power Connector Replacement, DC Power Connector: step 5, image 1 of 1
    • Desolder the back of the motherboard where the power connector is located.
1 Guide Comment
Later? I cant see to other
ISAAC SALAZAR - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 444
