Digiland 10.1'' DL1016 Power Button Replacement
  1. Digiland 10.1'' DL1016 Power Button Replacement, Digiland 10.1'' DL1016 Remove Backing: step 1, image 1 of 2 Digiland 10.1'' DL1016 Power Button Replacement, Digiland 10.1'' DL1016 Remove Backing: step 1, image 2 of 2
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Power Button Replacement: step 2, image 1 of 2 Digiland 10.1'' DL1016 Power Button Replacement: step 2, image 2 of 2
    • Gently lift the backing off.
  3. Careful: step 3 is sourced from a guide that's marked as in-progress.
    Digiland 10.1'' DL1016 Power Button Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: step 3, image 1 of 2 Digiland 10.1'' DL1016 Power Button Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: step 3, image 2 of 2
    • Gently pull the wiring back.
    • You may need to use a metal spudger to lift the wire connector off the back of the screen.
  4. Digiland 10.1'' DL1016 Power Button Replacement, Power Button: step 4, image 1 of 1
    • Disconnect the black cable off the motherboard.
    • Remove the four 1.5mm Phillips #000 screws from the motherboard.
  5. Digiland 10.1'' DL1016 Power Button Replacement: step 5, image 1 of 2 Digiland 10.1'' DL1016 Power Button Replacement: step 5, image 2 of 2
    • Make sure the ribbon cables are free or unconnected so the motherboard is able to be moved.
    • Use a metal spudger to slide underneath the motherboard and push it up so it's unstuck from the tablet.
    • Lift up the motherboard and place it somewhere that is clean and kept safe.
CRISTIAN RAMIREZ
91 Reputation
1 Guide authored
Gateway, Team S1-G2, Saknee Fall 2019 Member of Gateway, Team S1-G2, Saknee Fall 2019
GCC-SAKNEE-F19S1G2
4 Members
5 Guides authored
4 Guide Comments
I want to know if ebay cheap 1 count usb charge port. Is okay to buy 4 This tablet. It is $3 or less & is all I need, I think. Just broke my tablet way worse on sloppy job of screen replacement , but it look ok. You see lint hair, etc underneath when screen off at an angle close uo is all & ruined power button area ceazy glue, etc mess I have to press down hard with something & now on top of all, the charger chord at same time plys charge lose all of a sudden so it isnt really charging or a hassle & if it is it turns off while playing on a game. etc. Now it is not even turning on. Just tries, but doesn't. At least b4 it was. I took it apart to see the charge port . Good thing its not a cable type & can easily replace for cheaoer then one too. I has wrong battery reading or diff on screen off then on have 2opush down, but charge port lose. I don’t know if replacing will fix it or it has other issue when I messed up the power button. I need 2 try the port till I can buy other tablet. If I had not broke it been okay. Lesson learned
Lily R - Reply
I had more to say just a bit, but I didn’t copy to paste it on 2nd post & I wish I had. S I'll n e went over chrts I just back arrow backspace deleted. Oh well. Nvm.
Lily R - Reply
How do you reconnect the black cable mine won't go back on
Deborah Thorp - Reply
What if the connection with the black cable broke off of the motherboard Is there a way to fix it I bought Kapton tape would that work?
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 13
All Time: 785
