Digitech XC- 5206 Buttons Replacement
  1. Digitech XC- 5206 Buttons Replacement, Speaker Buttons: step 1, image 1 of 2 Digitech XC- 5206 Buttons Replacement, Speaker Buttons: step 1, image 2 of 2
    • Remove front panel by forcefully placing the flat edge of the spudger in between panel and plastic. Angle spudger and use fingers to pry panel off.
    • You may need to use extra force.
  2. Digitech XC- 5206 Buttons Replacement: step 2, image 1 of 3 Digitech XC- 5206 Buttons Replacement: step 2, image 2 of 3 Digitech XC- 5206 Buttons Replacement: step 2, image 3 of 3
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Buttons Replacement: step 3, image 1 of 1
    • Unscrew upper panel two 10 mm screws spinning a size PH2 screwdriver in a counterclockwise motion.
  4. Digitech XC- 5206 Buttons Replacement: step 4, image 1 of 3 Digitech XC- 5206 Buttons Replacement: step 4, image 2 of 3 Digitech XC- 5206 Buttons Replacement: step 4, image 3 of 3
    • Remove circuit board by pulling straight upwards out of slot.
    • Remove plastic buttons by gently pushing buttons from top of speaker and using other hand to pull from bottom.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 172
