Dirt Devil Scorpion Quick Flip Motor Replacement
  1. Dirt Devil Scorpion Quick Flip Motor Replacement, Motor: step 1, image 1 of 1
    • Gently remove filter adapter from the vacuum body by pressing the gray plastic release button.
  2. Dirt Devil Scorpion Quick Flip Motor Replacement: step 2, image 1 of 1
    • Place the vacuum body on its left side and remove all 4mm screws with a Phillips #1 screwdriver.
  3. Dirt Devil Scorpion Quick Flip Motor Replacement: step 3, image 1 of 1
    • Carefully take apart the shell of the vacuum body.
    • Cut the two wires attached to the motor and remove the motor from the body.
  4. Dirt Devil Scorpion Quick Flip Motor Replacement: step 4, image 1 of 1
    • Solder the wires from the replacement motor to the wires connecting it to the power cord.
    • Carefully place the replacement motor back into its correct position in the vacuum body.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 514
