Disassembling Acer Aspire 7551G
Kevin D
Kevin D and 4 other contributors
Last updated on September 15, 2020
1 hour
Moderate
Community-Contributed Guide
Introduction
Go to step 1
Maintenance is an extremely important aspect of using a laptop. This guide will demonstrate how to disassemble the Acer Aspire 7551G for the purposes of cleaning, upgrading, or part replacement.
Before the start of the disassembly process, make sure to disconnect the laptop from its power supply and place the device on a flat work surface with plenty of space around it to avoid mishandling the delicate components.
Tools
Show more…
  1. Disassembling Acer Aspire 7551G, Disassembling Acer Aspire 7551G: step 1, image 1 of 2 Disassembling Acer Aspire 7551G, Disassembling Acer Aspire 7551G: step 1, image 2 of 2
    • Remove the battery by sliding the locking latch to the right and pull the battery out.
  2. Disassembling Acer Aspire 7551G: step 2, image 1 of 1
    • Use Phillips #000 Screwdriver to remove the case holding screws, remove the 4 screws that hold the back panel.
    • Apply gentle pressure when undoing the screws to preserve the condition of screw heads for future repairs or servicing.
    • It is important to manage all the extracted screws in a manner that will allow you to quickly place them where they belong during the reassembly process. You can take pictures of each step to memorize the screw placement, or purchase a magnetic pad and section the screws on it.
  3. Disassembling Acer Aspire 7551G, removing hard drive: step 3, image 1 of 3 Disassembling Acer Aspire 7551G, removing hard drive: step 3, image 2 of 3 Disassembling Acer Aspire 7551G, removing hard drive: step 3, image 3 of 3
    • To remove the hard drive, undo the screw that holds it in place and carefully pull the HDD to the right.
  4. Disassembling Acer Aspire 7551G: step 4, image 1 of 2 Disassembling Acer Aspire 7551G: step 4, image 2 of 2
    • To remove the RAM modules just click the metal levers to the right.
    • Remove two black screws from the WiFi card.
    • While removing the antenna wires, make sure to memorize or take a picture of their color and position.
  5. Disassembling Acer Aspire 7551G, removing dvd bay.: step 5, image 1 of 3 Disassembling Acer Aspire 7551G, removing dvd bay.: step 5, image 2 of 3 Disassembling Acer Aspire 7551G, removing dvd bay.: step 5, image 3 of 3
    • Using the Phillips #000 Screwdriver remove the screw that hold the DVD bay in place.
    • Use a spudger to pry the DVD bay away from the case.
  6. Disassembling Acer Aspire 7551G, removing case screws: step 6, image 1 of 3 Disassembling Acer Aspire 7551G, removing case screws: step 6, image 2 of 3 Disassembling Acer Aspire 7551G, removing case screws: step 6, image 3 of 3
    • Use Phillips #000 Screwdriver to remove the case holding screws.
    • Remember to only apply gentle pressure when undoing the screws to preserve the condition of screw heads for future repairs or servicing.
  7. Disassembling Acer Aspire 7551G, remove screws part 2: step 7, image 1 of 3 Disassembling Acer Aspire 7551G, remove screws part 2: step 7, image 2 of 3 Disassembling Acer Aspire 7551G, remove screws part 2: step 7, image 3 of 3
  8. Disassembling Acer Aspire 7551G, removing the screws part 3: step 8, image 1 of 3 Disassembling Acer Aspire 7551G, removing the screws part 3: step 8, image 2 of 3 Disassembling Acer Aspire 7551G, removing the screws part 3: step 8, image 3 of 3
  9. Disassembling Acer Aspire 7551G, remove the keyboard: step 9, image 1 of 3 Disassembling Acer Aspire 7551G, remove the keyboard: step 9, image 2 of 3 Disassembling Acer Aspire 7551G, remove the keyboard: step 9, image 3 of 3
    • To remove the keyboard, pop the three latches away from the keyboard with a spudger.
    • Gently pull the keyboard from the laptop, but be careful not to damage a flex cable that connect it to the motherboard.
  10. Disassembling Acer Aspire 7551G, remove keyboard flex cable: step 10, image 1 of 2 Disassembling Acer Aspire 7551G, remove keyboard flex cable: step 10, image 2 of 2
    • Move the flex cable away from the keyboard.
    • Place a Flathead screwdriver under the head of the cable and pry it upwards.
  11. Disassembling Acer Aspire 7551G, remove screws and cables of mid frame: step 11, image 1 of 3 Disassembling Acer Aspire 7551G, remove screws and cables of mid frame: step 11, image 2 of 3 Disassembling Acer Aspire 7551G, remove screws and cables of mid frame: step 11, image 3 of 3
    • Use the IC Extractor/Connector Puller to remove the cables.
    • These connectors are extremely fragile, only use minimal force and extreme care.
    • Use the Phillips #000 Screwdriver to remove the frame screws.
  12. Disassembling Acer Aspire 7551G, removing the screen: step 12, image 1 of 3 Disassembling Acer Aspire 7551G, removing the screen: step 12, image 2 of 3 Disassembling Acer Aspire 7551G, removing the screen: step 12, image 3 of 3
    • Remove all black plastic stickers to reveal the hidden screws.
    • Use Phillips #000 Screwdriver to remove the hidden screws.
    • Carefully slide your prybar under the edge and gently pry around the perimeter.
    • Remove the cable from the webcam module
    • Remove the screws that hold the screen to the inner frame.
  13. Disassembling Acer Aspire 7551G, removing the screen part 2: step 13, image 1 of 1
    • Gently unplug the LCD cable.
  14. Disassembling Acer Aspire 7551G, opening the case: step 14, image 1 of 3 Disassembling Acer Aspire 7551G, opening the case: step 14, image 2 of 3 Disassembling Acer Aspire 7551G, opening the case: step 14, image 3 of 3
    • Use the iSesamo Opening Tool to pry under the outer edge of the laptop body.
    • After hearing the first click, move the tool around the perimeter until all of the clips are undone.
    • While some force will be required in this step, make sure not to over-apply pressure since extra force might break the plastic clips.
    • After the clips are undone, remove the back cover.
  15. Disassembling Acer Aspire 7551G, removing mainboard: step 15, image 1 of 3 Disassembling Acer Aspire 7551G, removing mainboard: step 15, image 2 of 3 Disassembling Acer Aspire 7551G, removing mainboard: step 15, image 3 of 3
    • Carefully remove the ribbon cable connecting the two halves of the motherboard.
    • Use Phillips #000 Screwdriver to remove the motherboard screws.
    • Use a plastic prybar to remove the LCD connector. Be careful not to break the cable or its plastic holder.
    • Unplug the DC jack cable before removing the motherboard.
  16. Disassembling Acer Aspire 7551G, remove mainboard part 2: step 16, image 1 of 3 Disassembling Acer Aspire 7551G, remove mainboard part 2: step 16, image 2 of 3 Disassembling Acer Aspire 7551G, remove mainboard part 2: step 16, image 3 of 3
    • Remove the disconnected DC jack from its holder.
    • Carefully lift the motherboard out of the case.
    • Use Phillips #000 Screwdriver to remove the screw that is holding the power PCB.
  17. Disassembling Acer Aspire 7551G, removing the DC jack.: step 17, image 1 of 1
    • If the replacement of the DC jack is necessary, use the IC Extractor/Connector Puller to safely unplug the connection.
  18. Disassembling Acer Aspire 7551G, remove cooling pads and fan: step 18, image 1 of 1
    • Use the IC Extractor/Connector Puller to safely unplug the fan power connector.
  19. Disassembling Acer Aspire 7551G, removing cooling pads and fan part 2: step 19, image 1 of 3 Disassembling Acer Aspire 7551G, removing cooling pads and fan part 2: step 19, image 2 of 3 Disassembling Acer Aspire 7551G, removing cooling pads and fan part 2: step 19, image 3 of 3
    • Use the Phillips #000 Screwdriver to remove the cooling pad screws.
    • Make sure that the screw pressure across the metal plate remain rather constant. Undo the screws by a couple of rotations each, removing them AT the same time.
    • Lift the cooling pads and the fan assembly.
    • Remove the old thermal compound, degrease the surface with rubbing alcohol.
    • Use a can of compressed air to clean the fan assembly.
5 other people completed this guide.
Kevin D
7,418 Reputation
21 Guides authored
3 Comments
Wonderful techniques to follow. Very good explation and practical work.
Sck - Reply
Thanks, glad i could help.
Kevin D - Reply
I know this is a super old post, but is the GPU removable on models with a dedicated graphics card?
Old tech still working - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 14,067
