Disassembling Ambient Weather AQIN Particulate Sensor
  1. Disassembling Ambient Weather AQIN Particulate Sensor, Particulate Sensor: step 1, image 1 of 3 Disassembling Ambient Weather AQIN Particulate Sensor, Particulate Sensor: step 1, image 2 of 3 Disassembling Ambient Weather AQIN Particulate Sensor, Particulate Sensor: step 1, image 3 of 3
    • Looking at the sensor from the bottom, you can see the two tabs/prongs that hold the outer case together.
    • There is a fine cable attaching the internal components of the PM sensor. Be careful not to disrupt/break it.
    • The internal housing will now be exposed. You can use the two tabs/prongs on this porting to remove that portion of the case.
    • Next, you can remove the 4 small screws holding the internal components to the outer shell.
  2. Disassembling Ambient Weather AQIN Particulate Sensor: step 2, image 1 of 2 Disassembling Ambient Weather AQIN Particulate Sensor: step 2, image 2 of 2
    • Once the unit is disassembled, you can locate the internal motor of the unit.
    • Using compressed air, you may remove any debris that has become lodged on the intake shield of the motor.
Tim Elafros
493 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 97
