You're viewing a previously published version of this guide.  View latest version
Older Newer
Disassembling Apple IIc Cover
Alexandria Weinberg
Alexandria Weinberg and 11 other contributors
Last updated on June 29, 2023
5 minutes
Easy
Introduction
Go to step 1
If your Apple IIc is having hardware problems, you will need to remove the cover to access most of the components. Use this guide for step-by-step instructions on how to safely do that.
Before work is done on any electronics, be sure to disconnect them from power.
Begin by having a large workspace so that parts can be kept neat and organized. Take care when prying in step 2 since the plastic may be brittle and susceptible to damage.
iFixit earns commission when you buy through these links.
  1. Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: step 1, image 1 of 2 Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: step 1, image 2 of 2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Disassembling Apple IIc Cover: step 2, image 1 of 2 Disassembling Apple IIc Cover: step 2, image 2 of 2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Disassembling Apple IIc Cover: step 3, image 1 of 2 Disassembling Apple IIc Cover: step 3, image 2 of 2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Disassembling Apple IIc Cover: step 4, image 1 of 2 Disassembling Apple IIc Cover: step 4, image 2 of 2
    • Lift the handle straight up to remove.
Alexandria Weinberg
601 Reputation
3 Guides authored
Cal Poly, Team 21-23, Maness Fall 2011 Member of Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Members
13 Guides authored
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 64
All Time: 10,254
