Disassembling Arnova 7K G3 Logic Board Ribbon Connectors
  1. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: step 1, image 1 of 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: step 1, image 2 of 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: step 1, image 3 of 3
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 2, image 1 of 2 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 2, image 2 of 2
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 3, image 1 of 1
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 4, image 1 of 2 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Peel the copper tape covering the ribbon connector with a set of tweezers.
  5. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 5, image 1 of 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 5, image 2 of 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 5, image 3 of 3
    • Locate the two gray pins on the ribbon connector.
    • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
    • Gently pull the ribbon cable out of the connection port.
  6. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 6, image 1 of 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 6, image 2 of 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: step 6, image 3 of 3
    • Locate the ribbon connector two.
    • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
    • Gently pull the ribbon out of the connection port.
Kue
301 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 330
