Disassembling Axis 214 PTZ Camera
  1. Disassembling Axis 214 PTZ Camera, Camera: step 1, image 1 of 2 Disassembling Axis 214 PTZ Camera, Camera: step 1, image 2 of 2
    • 4 screws
  2. Disassembling Axis 214 PTZ Camera: step 2, image 1 of 3 Disassembling Axis 214 PTZ Camera: step 2, image 2 of 3 Disassembling Axis 214 PTZ Camera: step 2, image 3 of 3
    • 7 screws
  3. Disassembling Axis 214 PTZ Camera: step 3, image 1 of 3 Disassembling Axis 214 PTZ Camera: step 3, image 2 of 3 Disassembling Axis 214 PTZ Camera: step 3, image 3 of 3
    • Remove (4) Phillips screws.
    • Carefully disconnect the ribbon connector.
  4. Disassembling Axis 214 PTZ Camera: step 4, image 1 of 3 Disassembling Axis 214 PTZ Camera: step 4, image 2 of 3 Disassembling Axis 214 PTZ Camera: step 4, image 3 of 3
    • If replacing the logic board, remove (2) cables at the connectors.
    • At the underside of the logic board, disconnect the connector.
  5. Disassembling Axis 214 PTZ Camera: step 5, image 1 of 3 Disassembling Axis 214 PTZ Camera: step 5, image 2 of 3 Disassembling Axis 214 PTZ Camera: step 5, image 3 of 3
    • Gently press back the plastic clip at both sides.
    • Remove 2 screws.
    • Remove (3) Phillip screws.
  6. Disassembling Axis 214 PTZ Camera, Odključitev heada: step 6, image 1 of 2 Disassembling Axis 214 PTZ Camera, Odključitev heada: step 6, image 2 of 2
    • Carefully disconnect ribbon and flex cables.
  7. Disassembling Axis 214 PTZ Camera: step 7, image 1 of 1
    • Remove (2) Phillip screws.
    • Remove (1) protective clip.
  8. Disassembling Axis 214 PTZ Camera: step 8, image 1 of 2 Disassembling Axis 214 PTZ Camera: step 8, image 2 of 2
    • Remove 2 screws one on each side.
    • Turn the latch mechanism to the right.
  9. Disassembling Axis 214 PTZ Camera: step 9, image 1 of 3 Disassembling Axis 214 PTZ Camera: step 9, image 2 of 3 Disassembling Axis 214 PTZ Camera: step 9, image 3 of 3
    • It is difficult to disassemble.
  10. Disassembling Axis 214 PTZ Camera: step 10, image 1 of 2 Disassembling Axis 214 PTZ Camera: step 10, image 2 of 2
    • Remove (4) recessed screws.
    • Disconnect flat Ribbon Cable.
2 other people completed this guide.
lukahlastec
163 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 25
All Time: 2,759
