Disassembling Cambridge Audio A3i Case
  1. Disassembling Cambridge Audio A3i Case, Case: step 1, image 1 of 1
    • Remove 2 screws from each side of the amplifier.
  2. Disassembling Cambridge Audio A3i Case: step 2, image 1 of 1
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Disassembling Cambridge Audio A3i Case: step 3, image 1 of 2 Disassembling Cambridge Audio A3i Case: step 3, image 2 of 2
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Disassembling Cambridge Audio A3i Case: step 4, image 1 of 1
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
3 other people completed this guide.
Colby
356 Reputation
3 Guides authored
Cal Poly, Team 28-36, Regan Spring 2010 Member of Cal Poly, Team 28-36, Regan Spring 2010
CPSU-REGAN-S10S28G36
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 4,163
