Disassembling Canon Pixma MP480 Rear and Side Panel
  1. Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: step 1, image 1 of 2 Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: step 1, image 2 of 2
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Disassembling Canon Pixma MP480 Rear and Side Panel: step 2, image 1 of 1
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
  3. Disassembling Canon Pixma MP480 Rear and Side Panel: step 3, image 1 of 1
    • Open the front tray.
  4. Disassembling Canon Pixma MP480 Rear and Side Panel: step 4, image 1 of 2 Disassembling Canon Pixma MP480 Rear and Side Panel: step 4, image 2 of 2
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Disassembling Canon Pixma MP480 Rear and Side Panel: step 5, image 1 of 2 Disassembling Canon Pixma MP480 Rear and Side Panel: step 5, image 2 of 2
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Disassembling Canon Pixma MP480 Rear and Side Panel: step 6, image 1 of 2 Disassembling Canon Pixma MP480 Rear and Side Panel: step 6, image 2 of 2
    • Pry open the side cover with the plastic opening tool.
  7. Disassembling Canon Pixma MP480 Rear and Side Panel: step 7, image 1 of 2 Disassembling Canon Pixma MP480 Rear and Side Panel: step 7, image 2 of 2
    • Flip the printer over so that the bottom of the printer is facing you.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Disassembling Canon Pixma MP480 Rear and Side Panel: step 8, image 1 of 2 Disassembling Canon Pixma MP480 Rear and Side Panel: step 8, image 2 of 2
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
6 other people completed this guide.
Kevin Cole
116 Reputation
1 Guide authored
Cal Poly, Team 19-41, Regan Winter 2013 Member of Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 Members
6 Guides authored
2 Comments
Good job!!!!
lhitvietnam - Reply
Where is the rest of disassembly?
bill roberts - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 21
All Time: 21,200
