Disassembling Canon PowerShot G16
  1. Disassembling Canon PowerShot G16, Battery: step 1, image 1 of 3 Disassembling Canon PowerShot G16, Battery: step 1, image 2 of 3 Disassembling Canon PowerShot G16, Battery: step 1, image 3 of 3
    • Open the battery flap on the bottom of the camera by applying pressure and pushing in the direction of the arrow.
    • Remove your finger and allow the flap to pop open.
  2. Disassembling Canon PowerShot G16: step 2, image 1 of 3 Disassembling Canon PowerShot G16: step 2, image 2 of 3 Disassembling Canon PowerShot G16: step 2, image 3 of 3
    • Push the brown lever so that it pivots counterclockwise.
    • Grip and remove the battery.
  3. Disassembling Canon PowerShot G16, Button Circuit Board: step 3, image 1 of 3 Disassembling Canon PowerShot G16, Button Circuit Board: step 3, image 2 of 3 Disassembling Canon PowerShot G16, Button Circuit Board: step 3, image 3 of 3
    • Remove the ring around the lens by simultaneously pressing the black button located at the bottom right of the ring and rotating the ring counterclockwise.
  4. Disassembling Canon PowerShot G16: step 4, image 1 of 1
    • Remove the four 3.3 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Disassembling Canon PowerShot G16: step 5, image 1 of 1
    • Remove the 3.3 mm screw on the right side of the viewfinder using a Phillips #00 screwdriver.
  6. Disassembling Canon PowerShot G16: step 6, image 1 of 1
    • Remove the two 3.3 mm screws near the speaker using a Phillips #00 screwdriver.
  7. Disassembling Canon PowerShot G16: step 7, image 1 of 1
    • Open the port cover by lifting up the tab with your finger and remove the 7.3 mm screw underneath the cover using a Phillips #00 screwdriver.
    • Remove the other 3.3 mm screw below the ports using a Phillips #00 screwdriver.
  8. Disassembling Canon PowerShot G16: step 8, image 1 of 2 Disassembling Canon PowerShot G16: step 8, image 2 of 2
    • Using your fingers, carefully pull the the back cover off by grabbing the bottom left of the back cover and pulling outwards.
  9. Disassembling Canon PowerShot G16: step 9, image 1 of 1
    • Using your fingers, carefully pry the front cover off starting at the bottom right.
  10. Disassembling Canon PowerShot G16: step 10, image 1 of 2 Disassembling Canon PowerShot G16: step 10, image 2 of 2
    • Remove the 3.8 mm screw at the bottom right of the port cover housing using a Phillips #00 screwdriver.
    • Lift away the port cover housing.
  11. Disassembling Canon PowerShot G16: step 11, image 1 of 1
    Tool used on this step:
    Buy
    • Reorient the camera so that you are looking at the back.
    • Make sure to pull the connector straight down as pulling up may cause harm to the connector.
    • Unplug the button circuit board from the motherboard by unlocking the ZIF connector (gently lift the brown lock that keeps the cable in place).
    • Pull the connector downwards with the tweezers.
  12. Disassembling Canon PowerShot G16: step 12, image 1 of 1
    • Remove the 3.0 mm screw on the top of the button memory board using a Phillips #00 screwdriver.
    • Remove the 2.8 mm screw on the bottom of the button memory board using a Phillips #00 screwdriver.
  13. Disassembling Canon PowerShot G16: step 13, image 1 of 1
    • Lift the button circuit board away from the camera.
  14. Disassembling Canon PowerShot G16, LCD: step 14, image 1 of 3 Disassembling Canon PowerShot G16, LCD: step 14, image 2 of 3 Disassembling Canon PowerShot G16, LCD: step 14, image 3 of 3
    • Do not pull the connector upwards as doing so may harm the connector housing.
    • Unlock the ZIF connector for the large connector ribbon by lifting up on the brown flap with the plastic opening tool.
    • Gently pull the connector straight out of the housing with your fingers.
  15. Disassembling Canon PowerShot G16: step 15, image 1 of 2 Disassembling Canon PowerShot G16: step 15, image 2 of 2
    • Unplug the small connector ribbon by pulling the cable outwards from the camera using a spudger or your fingers.
  16. Disassembling Canon PowerShot G16: step 16, image 1 of 1
    • Be careful of the copper plate that may fall out once you lift the LCD screen away.
    • Gently lift the LCD away from the camera housing.
  17. Disassembling Canon PowerShot G16, Motherboard: step 17, image 1 of 2 Disassembling Canon PowerShot G16, Motherboard: step 17, image 2 of 2
    • Be careful not to bend the EMI shield.
    • Lift and remove the copper EMI shield.
  18. Disassembling Canon PowerShot G16: step 18, image 1 of 1
    • Reorient the camera so that you are looking at the front.
    • Remove the 2.8 mm screw right above the screw holding the lens on using a Phillips #00 screwdriver.
    • Remove the 3.3 mm black screw to the left of the front viewfinder using a Phillips #000 screwdriver.
  19. Disassembling Canon PowerShot G16: step 19, image 1 of 1
    • Remove the 6.8 mm screw to the left of the rear viewfinder using a Phillips #00 screwdriver.
    • Remove the 5.2 mm screw to the right of the rear viewfinder using a Phillips #00 screwdriver.
  20. Disassembling Canon PowerShot G16: step 20, image 1 of 2 Disassembling Canon PowerShot G16: step 20, image 2 of 2
    • Remove the top 2.3 mm screw from the side with the ports using a Phillips #00 screwdriver.
    • Remove the 4 mm screw right below the one you just removed using a Phillips #00 screwdriver.
  21. Disassembling Canon PowerShot G16: step 21, image 1 of 2 Disassembling Canon PowerShot G16: step 21, image 2 of 2
    • Reorient the camera so that you are looking at the back of the camera.
    • Remove the rear viewfinder casing by firmly gripping it and pulling it out bottom first.
    • When reassembling, make sure that the viewfinder is fitted correctly beneath the top cover.
  22. Disassembling Canon PowerShot G16: step 22, image 1 of 1
    • Remove the newly uncovered 2.8 mm screw from the right of the viewfinder using a Phillips #00 screwdriver.
    • Remove the 4.9 mm screw from top right of the metal casing on the back using a Phillips #00 screwdriver.
    • Remove the 4.3 mm screw from bottom right of the metal casing on the back using a Phillips #00 screwdriver.
    • Remove the newly uncovered screws from the right of the viewfinder using a Phillips #00 screwdriver. (Note, they're already removed on the picture)
  23. Disassembling Canon PowerShot G16: step 23, image 1 of 1
    • Remove the 2.7 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
  24. Disassembling Canon PowerShot G16: step 24, image 1 of 1
    • Reorient the camera so that you are looking at the side with the black felt circle.
    • Use caution around this black felt covered circle that is right below the screw to be removed. This is the speaker and can easily be damaged if pressed too hard or poked with a screwdriver.
    • Remove the 2.8 mm screw from the right side of the camera if you are looking at the front lens using a Phillips #00 screwdriver.
  25. Disassembling Canon PowerShot G16: step 25, image 1 of 1
    • Remove the metal casing from the back by lifting it away from the camera.
  26. Disassembling Canon PowerShot G16: step 26, image 1 of 1
    • Disconnect the cable on the top of the motherboard by lifting it up vertically using a plastic opening tool.
  27. Disassembling Canon PowerShot G16: step 27, image 1 of 2 Disassembling Canon PowerShot G16: step 27, image 2 of 2
    • Disconnect the cable on the back of the camera to the left of the viewfinder by lifting it up vertically using a plastic opening tool.
  28. Disassembling Canon PowerShot G16: step 28, image 1 of 2 Disassembling Canon PowerShot G16: step 28, image 2 of 2
    • Remove the top portion of the casing by firmly grasping it and pulling it upward to lift it off.
    • Some force may be required, but be careful to not bend either side of the top casing up too much or you will damage it.
  29. Disassembling Canon PowerShot G16: step 29, image 1 of 3 Disassembling Canon PowerShot G16: step 29, image 2 of 3 Disassembling Canon PowerShot G16: step 29, image 3 of 3
    • Open the two ZIF connectors by flipping them up using a plastic opening tool on the motherboard.
    • Make sure to pull the cable ribbon straight out and not up because pulling it up may harm the connector.
    • Be careful not to pinch the cable while pulling it out because it can easily be damaged if pinched. It is helpful to pull it out by the tabs that are built into the connector ribbon.
    • Disconnect the two cable ribbons by pulling them straight out.
  30. Disassembling Canon PowerShot G16: step 30, image 1 of 2 Disassembling Canon PowerShot G16: step 30, image 2 of 2
    • Disconnect the lens cable from the motherboard by lifting it up vertically from the motherboard using a plastic opening tool.
  31. Disassembling Canon PowerShot G16: step 31, image 1 of 2 Disassembling Canon PowerShot G16: step 31, image 2 of 2
    Buy
    • Be careful not to pinch the cable while pulling it out because it can easily be damaged. It is helpful to pull it out by the tabs that are built into the connector ribbon.
    • Remove the small cable towards the top by pulling it straight out of its connector using tweezers or your fingers.
    • Remove both Screws on the bottom side of the motherboard
  32. Disassembling Canon PowerShot G16: step 32, image 1 of 1
    • Lift the motherboard out of the camera.
  33. Disassembling Canon PowerShot G16, Lens: step 33, image 1 of 1
    • Reorient the camera so that black lens cover is facing you with viewfinder on top.
    • Remove the four 5.3 mm screws around the lens using a Phillips #00 screwdriver.
    • Remove the 3.8 mm screw above the lens using a Phillips #00 screwdriver.
  34. Disassembling Canon PowerShot G16: step 34, image 1 of 1
    • Remove the black plastic cover surrounding the lens by gripping and lifting upwards.
  35. Disassembling Canon PowerShot G16: step 35, image 1 of 1
    • Remove the black 3.8 mm screw on the far left side using a Phillips #000 screwdriver.
  36. Disassembling Canon PowerShot G16: step 36, image 1 of 2 Disassembling Canon PowerShot G16: step 36, image 2 of 2
    • Grip the left and right halves of the camera and wiggle them apart.
  37. Disassembling Canon PowerShot G16: step 37, image 1 of 1
    • Use caution around the black felt covered circle. This is the speaker and can easily be damaged.
    • Pick up the half of the camera that contains the lens.
    • Remove top 4 mm screw from the strap holder using a Phillips #00 screwdriver.
    • Remove the middle 3.8 mm screw next to the left speaker using a Phillips #00 screwdriver.
  38. Disassembling Canon PowerShot G16: step 38, image 1 of 1
    • Remove the cable strap bracket by lifting it away.
  39. Disassembling Canon PowerShot G16: step 39, image 1 of 1
    • Do not pull the connector upwards because doing so may harm the connector housing.
    • Be carful not to pinch the cable while pulling it out.
    • Disconnect the cable in the top left by pulling it straight out of its connector.
  40. Disassembling Canon PowerShot G16: step 40, image 1 of 2 Disassembling Canon PowerShot G16: step 40, image 2 of 2
    • Lift the metal frame away from the lens.
    • After you remove the metal frame, the lens will be by itself.
  41. Disassembling Canon PowerShot G16, Disassembling Canon PowerShot G16: step 41, image 1 of 1
    • Remove the two 2.8 mm screws on the top of the lens assembly near the viewfinder using a Phillips #00 screwdriver.
  42. Disassembling Canon PowerShot G16: step 42, image 1 of 2 Disassembling Canon PowerShot G16: step 42, image 2 of 2
    • Lift the viewfinder away from the lens assembly.
  43. Disassembling Canon PowerShot G16: step 43, image 1 of 2 Disassembling Canon PowerShot G16: step 43, image 2 of 2
    • Grab the metal frame with the flash assembly that was removed from around the lens assembly.
    • Remove the 2 mm screw on the circuit board using a Phillips #00 screwdriver.
    • Lift and remove the circuit board from the flash assembly.
  44. Disassembling Canon PowerShot G16: step 44, image 1 of 1
    • Here our journey ends. Now the journey of reassembly begins.
8 other people completed this guide.
Jonathan Harger
1,270 Reputation
5 Guides authored
Cal Poly, Team 70-6, Forte Winter 2016 Member of Cal Poly, Team 70-6, Forte Winter 2016
CPSU-FORTE-W16S70G6
4 Members
7 Guides authored
6 Guide Comments
Excellent guide, thank you so much. My camera has an intermittent fault so I should now be able to save a lot of time and money by trying myself to find the possible loose connection inside.
Aspivenin - Reply
Moisture ring on inside of lens. No way to clean this off. Also, shutter release button gone: no replacement found anywhere.
ewchnsw - Reply
Thank you SO MUCH. One of our company cameras, a PowerShot G15 had a dead display. A person on the Canonforum…
https://community.usa.canon.com/t5/Power...
…recommended disassembling the camera via iFixit instructions for the G16 (slightly different than the G15), unplugging the display, and plugging it back in again…WHICH WORKED. Did the whole thing in about 30 minutes. Awesome. Saved us a lot of money. Very grateful.
Scott Morrison - Reply
Hi,
Could you describe how to disassemble and assemble the lens curtain - th esix leaves and two springs that cover the lens when the lens is retracted into the camera? I’ve tried to assemble it, but end up with the mechanism only closing 2/3rd way. It opens fine. I want to replace my scratched lens with an unscratched one, but the new one is the one with the curtain problem. Thank you!
H Stahl - Reply
i have the same question...
SebastianM -
Past 24 Hours: 8
Past 7 Days: 33
Past 30 Days: 127
All Time: 12,529
