Disassembling Canon PowerShot SD1100 IS LCD screen
  1. Disassembling Canon PowerShot SD1100 IS LCD screen, Front and Rear Cover: step 1, image 1 of 2 Disassembling Canon PowerShot SD1100 IS LCD screen, Front and Rear Cover: step 1, image 2 of 2
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS LCD screen: step 2, image 1 of 3 Disassembling Canon PowerShot SD1100 IS LCD screen: step 2, image 2 of 3 Disassembling Canon PowerShot SD1100 IS LCD screen: step 2, image 3 of 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS LCD screen: step 3, image 1 of 3 Disassembling Canon PowerShot SD1100 IS LCD screen: step 3, image 2 of 3 Disassembling Canon PowerShot SD1100 IS LCD screen: step 3, image 3 of 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS LCD screen: step 4, image 1 of 1
    • The cases should now be removed.
  5. Disassembling Canon PowerShot SD1100 IS LCD screen, LCD screen: step 5, image 1 of 2 Disassembling Canon PowerShot SD1100 IS LCD screen, LCD screen: step 5, image 2 of 2
    • Remove the top-left screw above the LCD screen (0.100 in).
    • Remove the C-shaped plate from the side of the LCD screen.
  6. Disassembling Canon PowerShot SD1100 IS LCD screen: step 6, image 1 of 2 Disassembling Canon PowerShot SD1100 IS LCD screen: step 6, image 2 of 2
    • Remove the screw from the top-right of the LCD screen (0.098 in).
    • Remove the L-shaped bar from the right of the LCD screen.
  7. Disassembling Canon PowerShot SD1100 IS LCD screen: step 7, image 1 of 2 Disassembling Canon PowerShot SD1100 IS LCD screen: step 7, image 2 of 2
    • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  8. Disassembling Canon PowerShot SD1100 IS LCD screen: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Be gentle. This ribbon should stay attached to the screen.
  9. Disassembling Canon PowerShot SD1100 IS LCD screen: step 9, image 1 of 3 Disassembling Canon PowerShot SD1100 IS LCD screen: step 9, image 2 of 3 Disassembling Canon PowerShot SD1100 IS LCD screen: step 9, image 3 of 3
    • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
    • Use the tweezers to lift this ribbon.
    • Use the tweezers to gently peel this ribbon from the one underneath it.
  10. Disassembling Canon PowerShot SD1100 IS LCD screen: step 10, image 1 of 1
    • The LCD screen should now be removed.
3 other people completed this guide.
Tyler Grossheim
1,470 Reputation
6 Guides authored
Cal Poly, Team 3-32, Regan Winter 2011 Member of Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 6
All Time: 3,632
