Disassembling Canon Powershot SD880 Logic Board
Juan Miguel
Juan Miguel and 4 other contributors
Last updated on January 28, 2014
10 - 15 minutes
Moderate
Action Shots
Missing Steps
Introduction
Go to step 1
The logic board is the brains behind the camera and should be handled delicately.
Tools
  1. Disassembling Canon Powershot SD880 Logic Board, Back Cover: step 1, image 1 of 3 Disassembling Canon Powershot SD880 Logic Board, Back Cover: step 1, image 2 of 3 Disassembling Canon Powershot SD880 Logic Board, Back Cover: step 1, image 3 of 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Disassembling Canon Powershot SD880 Logic Board, Front Cover: step 2, image 1 of 3 Disassembling Canon Powershot SD880 Logic Board, Front Cover: step 2, image 2 of 3 Disassembling Canon Powershot SD880 Logic Board, Front Cover: step 2, image 3 of 3
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
  3. Disassembling Canon Powershot SD880 Logic Board, Top Panel: step 3, image 1 of 2 Disassembling Canon Powershot SD880 Logic Board, Top Panel: step 3, image 2 of 2
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
  4. Disassembling Canon Powershot SD880 Logic Board, Logic Board: step 4, image 1 of 1
    • Remove 2 screws(1.75mm) using a screwdriver.
    • Detach 3 ribbons by pulling up on them. All are on the front of the camera.
  5. Disassembling Canon Powershot SD880 Logic Board: step 5, image 1 of 2 Disassembling Canon Powershot SD880 Logic Board: step 5, image 2 of 2
    • Remove the newly exposed screw(1.75mm) with screwdriver.
    • Unhinge the black tab to slide out the ribbon.
    • The only thing keeping logic board in place is a black nub. Lift the logic board from that corner with increasing force until it pops out.
Juan Miguel
104 Reputation
1 Guide authored
Cal Poly, Team 13-3, Forte Winter 2011 Member of Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 2,068
