Disassembling Canon Powershot SD880 Menu Button
  1. Disassembling Canon Powershot SD880 Menu Button, Back Cover: step 1, image 1 of 3 Disassembling Canon Powershot SD880 Menu Button, Back Cover: step 1, image 2 of 3 Disassembling Canon Powershot SD880 Menu Button, Back Cover: step 1, image 3 of 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Disassembling Canon Powershot SD880 Menu Button, Menu Button: step 2, image 1 of 3 Disassembling Canon Powershot SD880 Menu Button, Menu Button: step 2, image 2 of 3 Disassembling Canon Powershot SD880 Menu Button, Menu Button: step 2, image 3 of 3
    • Remove 2 screws from back of camera using screwdriver.
    • Remove 2 screws holding metal side guard using screwdriver.
    • Remove the connecting ribbon by pulling it straight out.
Ben Tupas
329 Reputation
3 Guides authored
Cal Poly, Team 13-3, Forte Winter 2011 Member of Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,464
