Disassembling Casio CZ-1000 Backplate
  1. Disassembling Casio CZ-1000 Backplate, Backplate: step 1, image 1 of 2 Disassembling Casio CZ-1000 Backplate, Backplate: step 1, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Disassembling Casio CZ-1000 Backplate: step 2, image 1 of 3 Disassembling Casio CZ-1000 Backplate: step 2, image 2 of 3 Disassembling Casio CZ-1000 Backplate: step 2, image 3 of 3
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Disassembling Casio CZ-1000 Backplate: step 3, image 1 of 3 Disassembling Casio CZ-1000 Backplate: step 3, image 2 of 3 Disassembling Casio CZ-1000 Backplate: step 3, image 3 of 3
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
Jace Alexander
181 Reputation
2 Guides authored
Cuesta, Team 60-3, Krynen Fall 2024 Member of Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 115
