Disassembling Chef's Choice M115 Case
  1. Disassembling Chef's Choice M115 Case, Case: step 1, image 1 of 2 Disassembling Chef's Choice M115 Case, Case: step 1, image 2 of 2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Disassembling Chef's Choice M115 Case: step 2, image 1 of 1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Disassembling Chef's Choice M115 Case: step 3, image 1 of 1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Disassembling Chef's Choice M115 Case: step 4, image 1 of 1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
4 other people completed this guide.
Zachary Grounds
580 Reputation
3 Guides authored
IUPUI, Team 3-3, Harley Fall 2015 Member of IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 Members
12 Guides authored
One Comment
Thank you for this information. Disassembly instructions for these units are not easy to find.
Robert Ford - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 29
All Time: 1,666
