Disassembling General Electric Telephone 2-9710A Handset
  1. Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: step 1, image 1 of 2 Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: step 1, image 2 of 2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Disassembling General Electric Telephone 2-9710A Handset: step 2, image 1 of 3 Disassembling General Electric Telephone 2-9710A Handset: step 2, image 2 of 3 Disassembling General Electric Telephone 2-9710A Handset: step 2, image 3 of 3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: step 3, image 1 of 2 Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: step 3, image 2 of 2
    • Remove the plastic cover with a plastic opening tool by gently sliding the tool underneath the plastic and pry the cover off.
  4. Disassembling General Electric Telephone 2-9710A Handset: step 4, image 1 of 1
    • Remove the paper with a plastic opening tool by gently sliding the tool underneath and prying the paper away from the phone.
  5. Disassembling General Electric Telephone 2-9710A Handset: step 5, image 1 of 2 Disassembling General Electric Telephone 2-9710A Handset: step 5, image 2 of 2
    • Remove the rubber stopper with a plastic opening tool by gently sliding the tool underneath and pry away from the phone.
  6. Disassembling General Electric Telephone 2-9710A Handset: step 6, image 1 of 2 Disassembling General Electric Telephone 2-9710A Handset: step 6, image 2 of 2
    • Remove the two 2.1 mm screws with a Phillips #1 screwdriver.
  7. Disassembling General Electric Telephone 2-9710A Handset: step 7, image 1 of 1
    • Pull apart the handset by pulling the top shell away from the other half of the phone.
  8. Disassembling General Electric Telephone 2-9710A Handset: step 8, image 1 of 2 Disassembling General Electric Telephone 2-9710A Handset: step 8, image 2 of 2
    • Remove 3 screws attaching the motherboard to shell.
    • Remove the 13 mm screw with a Philips #1 screwdriver.
    • Remove the two 13 mm screws with washers with a Philips #1 screwdriver.
  9. Disassembling General Electric Telephone 2-9710A Handset: step 9, image 1 of 2 Disassembling General Electric Telephone 2-9710A Handset: step 9, image 2 of 2
    • Slide the phone jack out from the shell by gently lifting up the female phone jack connector.
  10. Disassembling General Electric Telephone 2-9710A Handset: step 10, image 1 of 1
    • Without removing the motherboard completely, pull up slightly and pivot the motherboard out of the shell.
    • Be careful not to pull the connectors out.
Alles Rebel
72 Reputation
3 Guides authored
Cal Poly, Team 16-59, Forte Fall 2012 Member of Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Members
17 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 15
All Time: 2,738
