Introduction
The Griffin iFM 4027 LCD screen cover is necessary for protecting the device’s LCD screen. The screen cover can be removed using the steps in this guide.
First, lodge the tip of the plastic iFixit opening tool into the top corner of the device.
Apply pressure upward with the iFixit Opening Tool. This should release the two panels away from each other.
Lodge the tip of the plastic opening tool into the top arc where the side and main part of the device meet.
Push the plastic opening tool upward until the side panel detaches.
Use your fingers to push down on the center button and move it to the left, sliding it out from under the front panel.
Once removed, set the center button aside.
Notice in the attached image that the backside of the button has an elevated corner. This corner must be applying pressure on the golden plate seen in the picture to the right. The center pressure point of the button must also apply pressure to the golden plate in the middle. These plates are both circled in red in the picture to the left.
Carefully slide in the button, flat side first (the side not containing the high corner).
Carefully remove the circuit board and attached LCD component from the device by pulling it towards the open left side.
After disassembly, the device components should look similar to that which is depicted in the cover image (top right of page).
