Disassembling HP Compaq dx2000MT Hard Drive
  1. Disassembling HP Compaq dx2000MT Hard Drive, Removing the HP Compaq dx2000MT Case Doors: step 1, image 1 of 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Disassembling HP Compaq dx2000MT Hard Drive: step 2, image 1 of 2 Disassembling HP Compaq dx2000MT Hard Drive: step 2, image 2 of 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Disassembling HP Compaq dx2000MT Hard Drive: step 3, image 1 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 3, image 2 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 3, image 3 of 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Disassembling HP Compaq dx2000MT Hard Drive: step 4, image 1 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 4, image 2 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 4, image 3 of 3
    • Once again, this may take considerable force.
  5. Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: step 5, image 1 of 3 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: step 5, image 2 of 3 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: step 5, image 3 of 3
    • Remove the IDE data and power cables from the hard drive.
  6. Disassembling HP Compaq dx2000MT Hard Drive: step 6, image 1 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 6, image 2 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 6, image 3 of 3
    • Remove the front bezel by pulling upwards and out from below the lowest air vent.
  7. Disassembling HP Compaq dx2000MT Hard Drive: step 7, image 1 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 7, image 2 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 7, image 3 of 3
    • Remove the external drive faceplate by removing the two Torx T15 screws.
  8. Disassembling HP Compaq dx2000MT Hard Drive: step 8, image 1 of 2 Disassembling HP Compaq dx2000MT Hard Drive: step 8, image 2 of 2
    • Remove the following screws:
    • Front Torx T15.
    • Torx T15 mounting the hard drive cage to the optical drive bay.
  9. Disassembling HP Compaq dx2000MT Hard Drive: step 9, image 1 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 9, image 2 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 9, image 3 of 3
    • Fully remove the hard drive cage by sliding it towards the back of the device and pulling down.
  10. Disassembling HP Compaq dx2000MT Hard Drive: step 10, image 1 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 10, image 2 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 10, image 3 of 3
    • Remove the two Torx T15 screws holding this side of the hard drive in place.
  11. Disassembling HP Compaq dx2000MT Hard Drive: step 11, image 1 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 11, image 2 of 3 Disassembling HP Compaq dx2000MT Hard Drive: step 11, image 3 of 3
    • Proceed to the other side of the hard drive cage.
  12. Disassembling HP Compaq dx2000MT Hard Drive: step 12, image 1 of 2 Disassembling HP Compaq dx2000MT Hard Drive: step 12, image 2 of 2
    • Remove the hard drive from the hard drive cage by pulling it outward from the cage.
4 other people completed this guide.
Eva Pong
101 Reputation
1 Guide authored
Cal Poly, Team 17-16, Regan Fall 2011 Member of Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Members
17 Guides authored
2 Comments
can i upgrade it to 500gb?
connor gouws - Reply
This was a bit misleading. The title of the article is “Disassembling HP Compaq dx2000MT Hard Drive.” Therefore, I expected to see someone actually disassembling a hard drive, which would have been really cool. Instead, the article shows only the removal of a hard drive from a desktop computer’s case. Perhaps the title should say “Removing HP Compaq dx2000MT Hard Drive” or at best “Disassembling HP Compaq dx2000MT Case.”
Thomas Daniel - Reply
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 55
All Time: 8,402
