Disassembling HTC Incredible 2 Mid Panel Housing
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Disassembling HTC Incredible 2 Mid Panel Housing, Disassembling HTC Incredible 2 Back Panel: step 1, image 1 of 2 Disassembling HTC Incredible 2 Mid Panel Housing, Disassembling HTC Incredible 2 Back Panel: step 1, image 2 of 2
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
  2. Disassembling HTC Incredible 2 Mid Panel Housing: step 2, image 1 of 1
    • Remove the rear panel from the phone.
  3. Disassembling HTC Incredible 2 Mid Panel Housing, Battery: step 3, image 1 of 1
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
  4. Disassembling HTC Incredible 2 Mid Panel Housing: step 4, image 1 of 2 Disassembling HTC Incredible 2 Mid Panel Housing: step 4, image 2 of 2
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  5. Disassembling HTC Incredible 2 Mid Panel Housing, SIM Card: step 5, image 1 of 2 Disassembling HTC Incredible 2 Mid Panel Housing, SIM Card: step 5, image 2 of 2
    • Apply pressure with your fingertip to the pressure clip beneath the SIM card.
    • While keeping pressure on the clip, use another finger to gently slide the SIM card down over the clip.
  6. Disassembling HTC Incredible 2 Mid Panel Housing: step 6, image 1 of 2 Disassembling HTC Incredible 2 Mid Panel Housing: step 6, image 2 of 2
    • Keep sliding SIM card until completely free from holding apparatus. Now remove the SIM card.
  7. Disassembling HTC Incredible 2 Mid Panel Housing, Mid Panel: step 7, image 1 of 1
    • Remove the seven 1.42 mm Torx T5 screws
  8. Disassembling HTC Incredible 2 Mid Panel Housing: step 8, image 1 of 2 Disassembling HTC Incredible 2 Mid Panel Housing: step 8, image 2 of 2
    • Use a plastic opening tool to run along the phone's side and lever mid panel upward.
    • Apply minimal pressure as the mid panel is very delicate.
  9. Disassembling HTC Incredible 2 Mid Panel Housing: step 9, image 1 of 1
    • Gently grasp and carefully lift mid panel up and away from the device with your fingers.
Robert Trujillo
246 Reputation
2 Guides authored
Cal Poly, Team 11-53, Amido Spring 2014 Member of Cal Poly, Team 11-53, Amido Spring 2014
CPSU-AMIDO-S14S11G53
5 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 115
