Disassembling HTC ONE V Bottom Assembly
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Disassembling HTC ONE V Bottom Assembly, Disassembling HTC ONE V Bottom Assembly: step 1, image 1 of 3 Disassembling HTC ONE V Bottom Assembly, Disassembling HTC ONE V Bottom Assembly: step 1, image 2 of 3 Disassembling HTC ONE V Bottom Assembly, Disassembling HTC ONE V Bottom Assembly: step 1, image 3 of 3
    • Power off your device.
    • Remove the bottom cover by sliding it off.
  2. Disassembling HTC ONE V Bottom Assembly: step 2, image 1 of 1
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
  3. Disassembling HTC ONE V Bottom Assembly: step 3, image 1 of 2 Disassembling HTC ONE V Bottom Assembly: step 3, image 2 of 2
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
  4. Disassembling HTC ONE V Bottom Assembly: step 4, image 1 of 3 Disassembling HTC ONE V Bottom Assembly: step 4, image 2 of 3 Disassembling HTC ONE V Bottom Assembly: step 4, image 3 of 3
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
Michael Lucido
852 Reputation
6 Guides authored
USF Tampa, Team 1-3, Blackwell Winter 2015 Member of USF Tampa, Team 1-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G3
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 127
