Disassembling HTC One V Back Case
  1. Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: step 1, image 1 of 3 Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: step 1, image 2 of 3 Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: step 1, image 3 of 3
    • Power off your device.
    • Remove the bottom cover by sliding it off.
  2. Disassembling HTC One V Back Case: step 2, image 1 of 1
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
  3. Disassembling HTC One V Back Case: step 3, image 1 of 2 Disassembling HTC One V Back Case: step 3, image 2 of 2
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
  4. Disassembling HTC One V Back Case: step 4, image 1 of 3 Disassembling HTC One V Back Case: step 4, image 2 of 3 Disassembling HTC One V Back Case: step 4, image 3 of 3
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
  5. Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: step 5, image 1 of 3 Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: step 5, image 2 of 3 Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: step 5, image 3 of 3
    • Use the plastic opening tool to pry open the rear camera panel.
    • Remove both screws that are securing the back case.
    • One 4.0 mm Phillips #0 screw.
    • One 3.0 mm Phillips #0 screw.
  6. Disassembling HTC One V Back Case: step 6, image 1 of 3 Disassembling HTC One V Back Case: step 6, image 2 of 3 Disassembling HTC One V Back Case: step 6, image 3 of 3
    • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
    • Pry from right to left to avoid potential damages to the ribbon.
  7. Disassembling HTC One V Back Case: step 7, image 1 of 3 Disassembling HTC One V Back Case: step 7, image 2 of 3 Disassembling HTC One V Back Case: step 7, image 3 of 3
    • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
    • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
3 other people completed this guide.
Michael Lucido
852 Reputation
6 Guides authored
USF Tampa, Team 1-3, Blackwell Winter 2015 Member of USF Tampa, Team 1-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G3
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 3,276
