Disassembling HTC One V Motherboard
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Disassembling HTC One V Motherboard, Disassembling HTC ONE V Bottom Assembly: step 1, image 1 of 3 Disassembling HTC One V Motherboard, Disassembling HTC ONE V Bottom Assembly: step 1, image 2 of 3 Disassembling HTC One V Motherboard, Disassembling HTC ONE V Bottom Assembly: step 1, image 3 of 3
    • Power off your device.
    • Remove the bottom cover by sliding it off.
  2. Disassembling HTC One V Motherboard: step 2, image 1 of 1
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
  3. Disassembling HTC One V Motherboard: step 3, image 1 of 2 Disassembling HTC One V Motherboard: step 3, image 2 of 2
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
  4. Disassembling HTC One V Motherboard: step 4, image 1 of 3 Disassembling HTC One V Motherboard: step 4, image 2 of 3 Disassembling HTC One V Motherboard: step 4, image 3 of 3
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
  5. Disassembling HTC One V Motherboard, Disassembling HTC One V Back Case: step 5, image 1 of 3 Disassembling HTC One V Motherboard, Disassembling HTC One V Back Case: step 5, image 2 of 3 Disassembling HTC One V Motherboard, Disassembling HTC One V Back Case: step 5, image 3 of 3
    • Use the plastic opening tool to pry open the rear camera panel.
    • Remove both screws that are securing the back case.
    • One 4.0 mm Phillips #0 screw.
    • One 3.0 mm Phillips #0 screw.
  6. Disassembling HTC One V Motherboard: step 6, image 1 of 3 Disassembling HTC One V Motherboard: step 6, image 2 of 3 Disassembling HTC One V Motherboard: step 6, image 3 of 3
    • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
    • Pry from right to left to avoid potential damages to the ribbon.
  7. Disassembling HTC One V Motherboard: step 7, image 1 of 3 Disassembling HTC One V Motherboard: step 7, image 2 of 3 Disassembling HTC One V Motherboard: step 7, image 3 of 3
    • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
    • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
  8. Disassembling HTC One V Motherboard, Battery: step 8, image 1 of 1
    • Pry up the battery with the flat end of the spudger.
  9. Disassembling HTC One V Motherboard: step 9, image 1 of 3 Disassembling HTC One V Motherboard: step 9, image 2 of 3 Disassembling HTC One V Motherboard: step 9, image 3 of 3
    • Gently lift up the battery away from the edge of its housing.
    • Use the point end of the spudger to push the connection out of its housing.
  10. Disassembling HTC One V Motherboard, Camera Lens: step 10, image 1 of 3 Disassembling HTC One V Motherboard, Camera Lens: step 10, image 2 of 3 Disassembling HTC One V Motherboard, Camera Lens: step 10, image 3 of 3
    • Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens.
  11. Disassembling HTC One V Motherboard: step 11, image 1 of 1
    • Pry off the camera lens using a plastic opening tool.
  12. Disassembling HTC One V Motherboard, Vibrator: step 12, image 1 of 2 Disassembling HTC One V Motherboard, Vibrator: step 12, image 2 of 2
    Tool used on this step:
    Buy
    • Pry the vibrator out of the housing with a spudger.
    • Using the tweezers, pull up on the connecting wires detaching the vibrator from the motherboard.
  13. Disassembling HTC One V Motherboard, Motherboard: step 13, image 1 of 3 Disassembling HTC One V Motherboard, Motherboard: step 13, image 2 of 3 Disassembling HTC One V Motherboard, Motherboard: step 13, image 3 of 3
    • Using the spudger lift the tabs on the highlighted, red and orange, ribbon connectors. Gently pull out the ribbons from their connectors.
    • Remove the 3.0 mm Phillips #0 screw.
  14. Disassembling HTC One V Motherboard: step 14, image 1 of 3 Disassembling HTC One V Motherboard: step 14, image 2 of 3 Disassembling HTC One V Motherboard: step 14, image 3 of 3
    Buy
    • Using tweezers, pull back on the tape located on the bottom corners of the motherboard.
  15. Disassembling HTC One V Motherboard: step 15, image 1 of 2 Disassembling HTC One V Motherboard: step 15, image 2 of 2
    • Use the spudger to push back the latch holding on the motherboard. While the latch is pushed back use the plastic opening tool to pry up the motherboard.
  16. Disassembling HTC One V Motherboard: step 16, image 1 of 1
    • Place your phone on its side so that you can gently pull up on the motherboard to expose its last connector.
    • Using the flat end of the spudger, pop of the connector.
Joshua Rhoden
256 Reputation
1 Guide authored
USF Tampa, Team 1-3, Blackwell Winter 2015 Member of USF Tampa, Team 1-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G3
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 111
