Disassembling IBM ThinkPad A30 Upper Case
  1. Disassembling IBM ThinkPad A30 Upper Case, Battery: step 1, image 1 of 2 Disassembling IBM ThinkPad A30 Upper Case, Battery: step 1, image 2 of 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: step 2, image 1 of 3 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: step 2, image 2 of 3 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: step 2, image 3 of 3
    • Remove the highlighted screw with a Phillips #1 screwdriver.
    • Pull the hard drive out.
  3. Disassembling IBM ThinkPad A30 Upper Case, Upper Case: step 3, image 1 of 1
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
  4. Disassembling IBM ThinkPad A30 Upper Case: step 4, image 1 of 1
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
  5. Disassembling IBM ThinkPad A30 Upper Case: step 5, image 1 of 2 Disassembling IBM ThinkPad A30 Upper Case: step 5, image 2 of 2
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
  6. Disassembling IBM ThinkPad A30 Upper Case: step 6, image 1 of 3 Disassembling IBM ThinkPad A30 Upper Case: step 6, image 2 of 3 Disassembling IBM ThinkPad A30 Upper Case: step 6, image 3 of 3
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
  7. Disassembling IBM ThinkPad A30 Upper Case: step 7, image 1 of 3 Disassembling IBM ThinkPad A30 Upper Case: step 7, image 2 of 3 Disassembling IBM ThinkPad A30 Upper Case: step 7, image 3 of 3
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
  8. Disassembling IBM ThinkPad A30 Upper Case: step 8, image 1 of 2 Disassembling IBM ThinkPad A30 Upper Case: step 8, image 2 of 2
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
  9. Disassembling IBM ThinkPad A30 Upper Case: step 9, image 1 of 3 Disassembling IBM ThinkPad A30 Upper Case: step 9, image 2 of 3 Disassembling IBM ThinkPad A30 Upper Case: step 9, image 3 of 3
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
Alan
380 Reputation
6 Guides authored
Cal Poly, Team 4-44, Amido Fall 2010 Member of Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Members
26 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 19
All Time: 2,329
