Disassembling Insignia NS-B2110 Bottom Panel
  1. Disassembling Insignia NS-B2110 Bottom Panel, Battery: step 1, image 1 of 2 Disassembling Insignia NS-B2110 Bottom Panel, Battery: step 1, image 2 of 2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Disassembling Insignia NS-B2110 Bottom Panel: step 2, image 1 of 2 Disassembling Insignia NS-B2110 Bottom Panel: step 2, image 2 of 2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
  3. Disassembling Insignia NS-B2110 Bottom Panel, Bottom Panel: step 3, image 1 of 1
    • With a Phillips #2 screwdriver, remove two 2mm screws.
  4. Disassembling Insignia NS-B2110 Bottom Panel: step 4, image 1 of 2 Disassembling Insignia NS-B2110 Bottom Panel: step 4, image 2 of 2
    • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
    • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  5. Disassembling Insignia NS-B2110 Bottom Panel: step 5, image 1 of 3 Disassembling Insignia NS-B2110 Bottom Panel: step 5, image 2 of 3 Disassembling Insignia NS-B2110 Bottom Panel: step 5, image 3 of 3
    • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
    • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
    • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
Nikki
104 Reputation
1 Guide authored
Cal Poly, Team 4-31, Amido Fall 2013 Member of Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 238
