Disassembling KDDI Kyocera A5521K Faceplate
  1. Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: step 1, image 1 of 3 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: step 1, image 2 of 3 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: step 1, image 3 of 3
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Disassembling KDDI Kyocera A5521K Faceplate: step 2, image 1 of 3 Disassembling KDDI Kyocera A5521K Faceplate: step 2, image 2 of 3 Disassembling KDDI Kyocera A5521K Faceplate: step 2, image 3 of 3
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Faceplate: step 3, image 1 of 3 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Faceplate: step 3, image 2 of 3 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Faceplate: step 3, image 3 of 3
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  4. Disassembling KDDI Kyocera A5521K Faceplate: step 4, image 1 of 1
    • Remove the screws using a Y0 screwdriver.
  5. Disassembling KDDI Kyocera A5521K Faceplate: step 5, image 1 of 3 Disassembling KDDI Kyocera A5521K Faceplate: step 5, image 2 of 3 Disassembling KDDI Kyocera A5521K Faceplate: step 5, image 3 of 3
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  6. Disassembling KDDI Kyocera A5521K Faceplate: step 6, image 1 of 1
    • Use the Y0 screwdriver to remove the screws.
  7. Disassembling KDDI Kyocera A5521K Faceplate: step 7, image 1 of 2 Disassembling KDDI Kyocera A5521K Faceplate: step 7, image 2 of 2
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  8. Disassembling KDDI Kyocera A5521K Faceplate: step 8, image 1 of 3 Disassembling KDDI Kyocera A5521K Faceplate: step 8, image 2 of 3 Disassembling KDDI Kyocera A5521K Faceplate: step 8, image 3 of 3
    • Separate the faceplate from the phone.
Dominic Grisafe
157 Reputation
10 Guides authored
Cal Poly, Team 28-25, Regan Spring 2010 Member of Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Members
20 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,720
