Disassembling KDDI Kyocera A5521K SD Card Slot
  1. Disassembling KDDI Kyocera A5521K SD Card Slot, Disassembling KDDI Kyocera A5521K Battery: step 1, image 1 of 3 Disassembling KDDI Kyocera A5521K SD Card Slot, Disassembling KDDI Kyocera A5521K Battery: step 1, image 2 of 3 Disassembling KDDI Kyocera A5521K SD Card Slot, Disassembling KDDI Kyocera A5521K Battery: step 1, image 3 of 3
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Disassembling KDDI Kyocera A5521K SD Card Slot: step 2, image 1 of 3 Disassembling KDDI Kyocera A5521K SD Card Slot: step 2, image 2 of 3 Disassembling KDDI Kyocera A5521K SD Card Slot: step 2, image 3 of 3
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Disassembling KDDI Kyocera A5521K SD Card Slot, Back Plate: step 3, image 1 of 2 Disassembling KDDI Kyocera A5521K SD Card Slot, Back Plate: step 3, image 2 of 2
    • Remove the four screws with the Y0 screwdriver.
  4. Disassembling KDDI Kyocera A5521K SD Card Slot: step 4, image 1 of 2 Disassembling KDDI Kyocera A5521K SD Card Slot: step 4, image 2 of 2
    • Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
    • Remove the two screws with a Y0 screwdriver.
  5. Disassembling KDDI Kyocera A5521K SD Card Slot: step 5, image 1 of 3 Disassembling KDDI Kyocera A5521K SD Card Slot: step 5, image 2 of 3 Disassembling KDDI Kyocera A5521K SD Card Slot: step 5, image 3 of 3
    • Rotate the phone 180 degrees.
    • Carefully separate the back plate from the remainder of the phone.
    • The back plate should now be detached from the rest of the phone.
  6. Disassembling KDDI Kyocera A5521K SD Card Slot, SD Card Slot: step 6, image 1 of 3 Disassembling KDDI Kyocera A5521K SD Card Slot, SD Card Slot: step 6, image 2 of 3 Disassembling KDDI Kyocera A5521K SD Card Slot, SD Card Slot: step 6, image 3 of 3
    • Rotate the phone approximately 45 degrees to the right.
    • Gently pry up the SD card slot with a spudger.
Dominic Grisafe
157 Reputation
10 Guides authored
Cal Poly, Team 28-25, Regan Spring 2010 Member of Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Members
20 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 2,984
