Disassembling Kindle 11 Removing electronic from the case
Locos
Locos
Last updated on March 28, 2025
10 - 30 minutes
Difficult
Community-Contributed Guide
Introduction
Go to step 1
Couldn't find any instructions for Kindle 11. Here are the steps necessary to get to the guts.
Included photos are of the device with water damage.
Tools
Show more…
  1. Disassembling Kindle 11 Removing electronic from the case, Heat up the front frame: step 1, image 1 of 1
    • The front frame of the device is secured with black double-sided tape. To make its removal easier, it is recommended to heat the frame using a heat gun set to approximately 120°C. It is important to avoid excessive heating of the screen. Alternatively, a heating plate can also be used.
  2. Disassembling Kindle 11 Removing electronic from the case, Remove front frame: step 2, image 1 of 1
    • Start prying, from outside edge using Opening Pick from any of top corners.
    • After grabbing tob frame, move pick to be parrarel to the screen. Try not to go too deep.
    • There are no cables on top of the device.
    • Then moving to the bottom of the device - be careful as there are some ribbon connections and the digitizer for the touch screen can be reached with the pick. Try to make it as shallow and parallel as possible.
  3. Disassembling Kindle 11 Removing electronic from the case, Remove frame screws: step 3, image 1 of 2 Disassembling Kindle 11 Removing electronic from the case, Remove frame screws: step 3, image 2 of 2
    • There are 8 screws - Torx T4. Remove them.
    • In the second image, you can see the exact position of the threaded inserts.
  4. Disassembling Kindle 11 Removing electronic from the case, Remove frame from outer case: step 4, image 1 of 1
    • There are 6 plastic latches on the outer case. Using pick tool, unlatch them starting from top corner of the device. Use 3 picks and use Jimmy to gently pull inner frame from outer case.
  5. Disassembling Kindle 11 Removing electronic from the case: step 5, image 1 of 1
    • Here is the back of the main frame. There is mainboard PCB and battery.
    • Batterie has been glued with easy removal adhesive.
    • Mainboard is screwd with 4 Torx T5 screws and also glued to metal frame.
Locos
1 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 28
All Time: 28
