Disassembling Kodak Advantix F350 View Finder
  1. Disassembling Kodak Advantix F350 View Finder, Back Cover: step 1, image 1 of 1
    • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
  2. Disassembling Kodak Advantix F350 View Finder: step 2, image 1 of 2 Disassembling Kodak Advantix F350 View Finder: step 2, image 2 of 2
    • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
  3. Disassembling Kodak Advantix F350 View Finder: step 3, image 1 of 3 Disassembling Kodak Advantix F350 View Finder: step 3, image 2 of 3 Disassembling Kodak Advantix F350 View Finder: step 3, image 3 of 3
    • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  4. Disassembling Kodak Advantix F350 View Finder: step 4, image 1 of 2 Disassembling Kodak Advantix F350 View Finder: step 4, image 2 of 2
    • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
  5. Disassembling Kodak Advantix F350 View Finder: step 5, image 1 of 2 Disassembling Kodak Advantix F350 View Finder: step 5, image 2 of 2
    • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
  6. Disassembling Kodak Advantix F350 View Finder: step 6, image 1 of 3 Disassembling Kodak Advantix F350 View Finder: step 6, image 2 of 3 Disassembling Kodak Advantix F350 View Finder: step 6, image 3 of 3
    • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
  7. Disassembling Kodak Advantix F350 View Finder, Front Cover: step 7, image 1 of 2 Disassembling Kodak Advantix F350 View Finder, Front Cover: step 7, image 2 of 2
    • Locate the 3 screws on the camera that hold the front cover of the camera to the camera body.
    • The first 2 are located on the bottom of the camera.
    • The last screw is located behind the flash module.
    • Turn the camera on, and raise the flash module to locate the flash module screw.
  8. Disassembling Kodak Advantix F350 View Finder: step 8, image 1 of 2 Disassembling Kodak Advantix F350 View Finder: step 8, image 2 of 2
    • Remove the 2 screws at the base of the camera housing.
    • Use the Phillips #00 Precision Screwdriver and remove the screws.
    • Repeat this process for the screw behind the flash module.
  9. Disassembling Kodak Advantix F350 View Finder: step 9, image 1 of 2 Disassembling Kodak Advantix F350 View Finder: step 9, image 2 of 2
    • Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver.
  10. Disassembling Kodak Advantix F350 View Finder: step 10, image 1 of 2 Disassembling Kodak Advantix F350 View Finder: step 10, image 2 of 2
    • Remove the flash cover.
    • Remove the flash module by twisting it up and outward of the camera housing.
    • The cover can now be be removed.
  11. Disassembling Kodak Advantix F350 View Finder: step 11, image 1 of 2 Disassembling Kodak Advantix F350 View Finder: step 11, image 2 of 2
    • Remove the film door lever.
    • Remove the screw holding the film lever in place by using a Phillips #00 Precision Screwdriver.
    • Using a plastic opening tool, gently pry the switch upwards to remove it.
  12. Disassembling Kodak Advantix F350 View Finder: step 12, image 1 of 1
    • Open the battery door by pushing the lever towards the arrow indicated.
  13. Disassembling Kodak Advantix F350 View Finder: step 13, image 1 of 3 Disassembling Kodak Advantix F350 View Finder: step 13, image 2 of 3 Disassembling Kodak Advantix F350 View Finder: step 13, image 3 of 3
    • Remove the front cover.
    • Insert your thumb in the film hole and gently pry the bottom loose.
    • Once the front is loose, gently pull it out.
  14. Disassembling Kodak Advantix F350 View Finder, Display: step 14, image 1 of 1
    • Locate the 3 screws on the top of the camera.
    • These will be removed in the next step.
  15. Disassembling Kodak Advantix F350 View Finder: step 15, image 1 of 3 Disassembling Kodak Advantix F350 View Finder: step 15, image 2 of 3 Disassembling Kodak Advantix F350 View Finder: step 15, image 3 of 3
    • Remove the 3 screws using the Phillips #00 Precision Screwdriver.
  16. Disassembling Kodak Advantix F350 View Finder: step 16, image 1 of 2 Disassembling Kodak Advantix F350 View Finder: step 16, image 2 of 2
    • Remove the LCD.
    • Gently pry the LCD and plastic bezel upward with a plastic opening tool.
    • Remove LCD and replace as needed.
  17. Disassembling Kodak Advantix F350 View Finder, View Finder: step 17, image 1 of 1
    • Locate the screw on the front of the camera that holds the view finder assembly.
  18. Disassembling Kodak Advantix F350 View Finder: step 18, image 1 of 1
    • Using the Phillips #00 Precision Screwdriver, remove the screw.
  19. Disassembling Kodak Advantix F350 View Finder: step 19, image 1 of 2 Disassembling Kodak Advantix F350 View Finder: step 19, image 2 of 2
    • Remove the 3 view finder covers.
    • The first one is metal and comes off easily.
    • The last two are plastic and tend to fall off, so gently remove them.
  20. Disassembling Kodak Advantix F350 View Finder: step 20, image 1 of 1
    • Locate the 2 screws on the top of the camera.
    • These are holding the view finder assembly in place.
  21. Disassembling Kodak Advantix F350 View Finder: step 21, image 1 of 2 Disassembling Kodak Advantix F350 View Finder: step 21, image 2 of 2
    • Use the Phillips #00 Precision Screwdriver to remove the screws.
  22. Disassembling Kodak Advantix F350 View Finder: step 22, image 1 of 2 Disassembling Kodak Advantix F350 View Finder: step 22, image 2 of 2
    • Remove the mount holding the view finder in place.
  23. Disassembling Kodak Advantix F350 View Finder: step 23, image 1 of 2 Disassembling Kodak Advantix F350 View Finder: step 23, image 2 of 2
    • Remove the front view finder.
    • Gently fold the plastic up from the back.
    • Pull up to remove the front view finder.
  24. Disassembling Kodak Advantix F350 View Finder: step 24, image 1 of 1
    • Gently grab the back view finder.
    • Slide up to remove from camera.
3 other people completed this guide.
David Cottrell
103 Reputation
5 Guides authored
UW Stout, Team 1-2, Zhou Fall 2011 Member of UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 1,154
