LG 440G Bottom Casing Replacement
  1. LG 440G Bottom Casing Replacement, Turn off phone.: step 1, image 1 of 1
    • Turn the device off.
    • To do so, press and hold the red button.
  2. LG 440G Bottom Casing Replacement, Flip phone.: step 2, image 1 of 1
    • Flip the phone over.
  3. LG 440G Bottom Casing Replacement, Rear cover removal.: step 3, image 1 of 1
    • Slide the rear cover downward
    • Lift it off to access the battery
  4. LG 440G Bottom Casing Replacement, Removal of battery.: step 4, image 1 of 1
    • Locate the small rounded recess to get access to the battery
    • Gently, lift the battery
  5. LG 440G Bottom Casing Replacement, Unscrew six screws along edges of casing: step 5, image 1 of 1
    • Use a Phillips #00 screw driver to remove six screws.
    • Save screws for reassembly.
  6. LG 440G Bottom Casing Replacement, Lift casing cover: step 6, image 1 of 2 LG 440G Bottom Casing Replacement, Lift casing cover: step 6, image 2 of 2
    • Run the plastic opening tool along the edge of the phone to release the casing cover.
    • Lift the casing cover.
Emily Class
107 Reputation
1 Guide authored
Ohio State, Team 1-1, Buehl Winter 2015 Member of Ohio State, Team 1-1, Buehl Winter 2015
OSU-BUEHL-W15S1G1
4 Members
8 Guides authored
1 Guide Comment
this would be most probably, the same guide to tear down the LG B470
douglas flores - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 1,821
