Disassembling LG VX8550 Case
  1. Disassembling LG VX8550 Case, Battery: step 1, image 1 of 1
    • Slide the battery release up.
  2. Disassembling LG VX8550 Case: step 2, image 1 of 1
    • Remove the battery by lifting away from the case.
  3. Disassembling LG VX8550 Case, Case: step 3, image 1 of 1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. Disassembling LG VX8550 Case: step 4, image 1 of 1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. Disassembling LG VX8550 Case: step 5, image 1 of 1
    • Use the iPod opening tool to pry off the back casing.
  6. Disassembling LG VX8550 Case: step 6, image 1 of 1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. Disassembling LG VX8550 Case: step 7, image 1 of 1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
Nathan Jones
89 Reputation
10 Guides authored
Cal Poly, Team 34-55, Forte Spring 2010 Member of Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Members
22 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 3,472
