Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,
  1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, First look: step 1, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, First look: step 1, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, First look: step 1, image 3 of 3
    • To open the laptop, first you have to unscrew the back-screws.
    • 1. remove the plastic/rubber caps
    • 2. unscrew the 12 screws.
    • ATTN: Do not forget!
    • unplug the laptop from power source & remove the batery
    • unscrew the 3 tiny screws behind the battery
    • keep the lid closed till later on
  2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Back - HDD, WIFI card,: step 2, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Back - HDD, WIFI card,: step 2, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Back - HDD, WIFI card,: step 2, image 3 of 3
    • Here you have some details regarding the back of the laptop. After you got read of the back cover you can access the following:
    • 1. WIFI card - Easy to change / replace There are two cables attached to it. Remove them, then unscrew the screw that holds the card in place and lift gently up - DONE.
    • 2. HDD / SSD. All you have to do is grab and pull the ribbon (as in photo). There are a few extra steps to change it.
  3. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Removing the keyboard: step 3, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Removing the keyboard: step 3, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Removing the keyboard: step 3, image 3 of 3
    • Now to remove or change the keyboard
    • 1. Insert gently the cutte (or other sharp tool) and press towards the screen & flip up slowly.
    • To remove it completely unplug the two connectors.
    • After removing the keyboard you find:
    • 1.ECO Button
    • 2. Sound
    • 3. Power button
    • 4. Mouse pad
  4. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Removing the screws to open the case: step 4, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Removing the screws to open the case: step 4, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Removing the screws to open the case: step 4, image 3 of 3
    • remove all the screws as shown in the images.
  5. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Splitting the case an upper side (under theh keyboard): step 5, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Splitting the case an upper side (under theh keyboard): step 5, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Splitting the case an upper side (under theh keyboard): step 5, image 3 of 3
    • Opening the case is easy, follow the steps as shown.
    • To change / remove the speakers remove the screws.
    • To change / remove the Eco/3D button or power button, yo have to remove first the speakers.
  6. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Change / remove speakers and buttons (Power and Eco/3D): step 6, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Change / remove speakers and buttons (Power and Eco/3D): step 6, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Change / remove speakers and buttons (Power and Eco/3D): step 6, image 3 of 3
    • Still more steps to come :), probably till 12... so min 6 more.
    • I will show you how to repair a broken hinge (plastic broken) - easy.
  7. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, CPU fan cable remove: step 7, image 1 of 1
    • Remove the fan cable
    • If you want to change the CPU fan, there are 2 screws that you have to remove (picture)
  8. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Start repairing the broken hinge: step 8, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Start repairing the broken hinge: step 8, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Start repairing the broken hinge: step 8, image 3 of 3
    • Broken hinge, detailed photo
  9. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Repairing the broken hinge [detailed photo]: step 9, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Repairing the broken hinge [detailed photo]: step 9, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Repairing the broken hinge [detailed photo]: step 9, image 3 of 3
    • Repairing the broken hinge [detailed photo]
  10. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Repairing the broken hinge [detailed photo] (2): step 10, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Repairing the broken hinge [detailed photo] (2): step 10, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Repairing the broken hinge [detailed photo] (2): step 10, image 3 of 3
    • do not forget about the grey cable attached on the bottom side.
    • When reattaching the cable, put some thermal paste on the contact (gray cable)
  11. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Fixing the hinge with plastic dowel pin: step 11, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Fixing the hinge with plastic dowel pin: step 11, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Fixing the hinge with plastic dowel pin: step 11, image 3 of 3
    • insert the plastic dowel pin from bottom-up and level it inside at the same height with other screw holes
  12. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Detailed img for inserting the plastic dowel pin: step 12, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Detailed img for inserting the plastic dowel pin: step 12, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Detailed img for inserting the plastic dowel pin: step 12, image 3 of 3
    • follow the pics
  13. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,: step 13, image 1 of 2 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,: step 13, image 2 of 2
    • add some thermalpaste to the gray cable
  14. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Outside & inside finishing: step 14, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Outside & inside finishing: step 14, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Outside & inside finishing: step 14, image 3 of 3
    • Cut the excess plastic from the dowel pin
    • Put some super-glue to fix it in place
  15. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Outside & inside finishing (2): step 15, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Outside & inside finishing (2): step 15, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Outside & inside finishing (2): step 15, image 3 of 3
    • I have glued some foam near the speakers in order to protect the aerea
  16. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Final touches: step 16, image 1 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Final touches: step 16, image 2 of 3 Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Final touches: step 16, image 3 of 3
    • Glue inside the plastic dowel pin
    • Use thermal paste to fix the gray cable (i have used silver paste)
10 other people completed this guide.
Oscar SOTAN
393 Reputation
1 Guide authored
2 Comments
I have a slipped HDMI port. At which step would I be able to access that?
Preston Ruottinen - Reply
My Toshibe C55T-B5349, I want to replace the "lid assembly" which includes the screen and digitizer. Can you give the steps? Thanks
RAM SAINATH - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 31
All Time: 35,336
